Adding waves with different scaling.
I have three waves each with their own x scaling. I can graph them easily enough on the same graph and IGOR places them properly with their respective offsets to eachother.
When I try adding them, I can see that it is just doing point for point addition, rather than adding according to the destination wave x scaling so that only the overlaps add. Here is what I tried:
Make/o/d/n=2000 wave_sum
setscale/i x,0,1100, wave_sum
wave_sum = wave_1 + wave_2 + wave_3 //each of which has their own x-scaling and in this case, each contains 200 points.
What am I doing wrong?
It is these types of problems that lead me to avoid wave scaling. Instead, I focus on recording an x-wave for each data set, ensuring it's the same for each. Of course this can't be done if you aren't the one collecting the data.
December 4, 2012 at 05:18 am - Permalink
Its a shame that the wave arithmetic functions cant duplicate what the graphing functions so easily achieve. I thought maybe it would just calculate (linearily between points) matching values for the new scaling, and go from there..
December 4, 2012 at 05:26 am - Permalink
wave_sum = wave_1 + wave_2 + wave_3where by default point-by-point arithmetic is used (i.e. by the point index
p), you should explicitly writewave_sum = wave_1(x) + wave_2(x) + wave_3(x)where the appropriate scaling of the waves is used.
Hope this helps,
Gregor
December 4, 2012 at 06:06 am - Permalink
wave_sum = wave_1(x) + wave_2(x) + wave_3(x)where the appropriate scaling of the waves is used.[/quote]To learn more about this, execute
DisplayHelpTopic "Indexing and Subranges".gregorK is right but there is one caveat: if the requested x value falls outside the x-range of the wave, then Igor will not extrapolate but will instead return the closest valid value. From the help: "If, in specifying a subrange, you use an X value that is out of range, Igor clips it to the closest valid X value." This is something to keep in mind when performing this type of assignments.
December 4, 2012 at 06:51 am - Permalink
December 4, 2012 at 07:09 am - Permalink
December 4, 2012 at 07:30 am - Permalink
So you get something like a section with your data, then a constant flat line on either end equal to the end points? Which gets added to the other functions? I suppose you could do something like wave_1(first_x,last_x) ?
December 4, 2012 at 07:34 am - Permalink
December 4, 2012 at 09:09 am - Permalink
Yes.
You have to be careful with these types of wave assignments because it is easy to ask for points for which Igor has no data. For example, if wave_sum covers a broader range than wave_1 then you are asking for non-existent data. So what you want to do is
[quote=johnweeks]working on just the common subset in X values[/quote]
Oh, and if you use
#pragma rtGlobals=3then an out-of-bounds access will result in an error. I recommend using it.December 4, 2012 at 11:52 pm - Permalink
Yes.
Oh, and if you use
#pragma rtGlobals=3then an out-of-bounds access will result in an error. I try to use this systematically, but be sure to read the documentation on it first.December 4, 2012 at 11:52 pm - Permalink
