Save Table Copy - Help
I am attempting to automatically create and save out (tab-delimited txt file) a table comprised of the results of an Igor procedure. The results are within a subfolder of the original waves and there are many result files. I would like all of the result files to be placed inside the same table/file for subsequent analysis outside of Igor. I tried to do this by simply finding the subfolder using the data browser, setting that as my current data folder and running a procedure similar to the example in the displayhelptopic for "savetablecopy".
//for example savealltables ("_none_"," ")
// "_none_" is used since the files are inside the current data folder
Function savealltables(pathName, fileName)
	String pathName		// Name of an Igor symbolic path.
	String fileName
	String tableName
	Variable index
	index = 0
	do
		tableName = WinName(index, 2)
		if (strlen(tableName) == 0)
			break
		SaveTableCopy/P=$pathName/W=$tableName/T=1/A=1 as fileName
		index += 1
	while(1)
When I run this procedure it creates a blank txt file. What am I doing wrong? The only way I can get the results in the file is if I create a new table within Igor containing all of the results, then running the save procedure. However, if I have to create the table using Windows>NewTable I might as well save it out using File>SaveTableCopy. I am trying to streamline the steps as much as possible since I am dealing with large batches of files.
Any help would be appreciated.
The term "table" in SaveTableCopy refers to an Igor table window that you have created. SaveTableCopy saves the text in the Igor table window to a file.
I get the feeling that you want to save the contents of all of the waves in the current data folder to a file. For that you need to create a list of wave names and then save it using Save/J. /J means "delimited text". Here is a crack (untested) at what I think you want to do:
Function SaveAllWavesInCDFAsText(pathName, fileName)
	String pathName
	String fileName
	// Create semicolon-separated list of all waves in current data folder
	String list = ""
	Variable numWaves = CountObjects(":", 1)
	Variable i
	for(i=0; i<numWaves; i+=1)
		String name = GetIndexedObjName(":", 1, i)
		list += name + ";"
	// Save waves as tab-delimited text
	Save/J/B/P=$pathName/O list as fileName
