Comparing strings
I am using Open /R refNum to open a file to read from. Then I use FReadLine refNum, LineOfText to get a line from the file. I want to have an if statment that goes like:
if (LineOfText=="")
put stuff here
but when I do this it doesn't compile and says LineOfText is an inappropiate name or symbol. How do I compare two strings.
Michael
If you want to test that there is text in the string you can use:
if(strlen(LineOfText) == 0)
    //put Stuff here
If you want to compare some strings you can use:
if(stringmatch(LineofText, "poo"))
    print "the lineoftext was poo"
As an aside, typically we use CmpStr instead of stringmatch because often we like the fact that CmpStr is case insensitive.
