Linear regression for non-overlapping segments of a wave
To analyse the persistence of share prices I have written a set of functions for the first time in my life. The function appears to work well and as always I am very impressed about the power of Igor Pro. Nevertheless, I need to re-write the last function (Fluctuationmagnitude), so that ultimately the regression analysis can be performed for segments of the wave instead of the entire wave, but I fail to see how this might be achieved.
What I would like to do is calculate the regression line first of all for a segment with the first 32 points, then for the subsequent 32 points, next for the third segment of 32 points, and so on, up to the 30th segment.
Per segment I would also like to calculate the Fluctuation magnitude (see variable Fluctuationmagn) and write the outcomes (a single real number for each of the 30 segments) to a wave, so that another curve fit can be performed. This time with the Fluctuation magnitude as the dependent factor and the segment number as the independent factor.
Any help is highly welcome. Many thanks in advance.
Eduard Kas
<code>#pragma rtGlobals=1       // Use modern global access method.
Function PriceTrend(Startlevel)
    Variable Startlevel     // Price of share at time = 0
    Variable Simulation = CreatePrices(Startlevel)  // Fuction to simulate random walk of share
                                                    // prices
    Variable Returncalc =  CalcReturn(input)        // Function to calculate  natural logs of return
                                                // per period
    Variable Demeanedcalc = Demeaned(periodreturn)      // Function to calculate demeaned returns
    Variable FFactor = Fluctuationmagnitude(squareddiff)    // Function to calculate local trend
                                                            // and fluctuation magnitude
Function CreatePrices(Startlevel)   // Function to simulate random walk of share prices
    Variable Startlevel //Share price at time = 0 in euros
    Make/O/N=961  input // Create wave for share prices
    Input[0] = Startlevel   // Share price at time = 0
    Input[1,960] =Input(p-1) + gnoise(0.15) // Share prices in subsequent period, where price is
                                            // price in preceding period plus period return drawn
                                            // from a Gaussian (noise) distribution
Function CalcReturn(input)  // Function to calculate natural logs of return per period
    Wave Input  // Read share prices  generated by preceding function
    String OutputName = NameOfWave(input)+"_logarithm"      // Store the name of wave plus
        // "logartihm" into the new wave
        // OuputName
    Duplicate/O input $OutputName   // Duplicate the wave with generated share prices as the
                                    // wave named input_logarithm
    Wave output = $OutputName       // Reference input_logarithm so that you can use it
    output = Ln(input)  // Calculate logarithmic values of wave
    Make/O/N=960 Periodreturn
    Periodreturn[0]= 0  // Assume return in first period to be zero
    Periodreturn[1,959] = output(p) - output(p-1)   // In next period logartihmic return equals logarithmic
                                            //  share price of this period minus logarithmic
                                            // share price in previous period
Function Demeaned(periodreturn) // Function to calculate demeaned returns
    Wave periodreturn   // Read return values generated by previous function
    WaveStats/Q periodreturn    // Determine statistis of return wave
    Variable avg = V_avg    // Determine average return
    Make/O/N=960 Cumulative // Create wave that will include each period's return above or
                                //  below the average for all periods
    Cumulative[0] = Periodreturn[0]-V_avg   // Determine return below or above the average for
                                        // the first period
    Cumulative[1,959] = Cumulative(p-1) + Periodreturn(p) - V_avg   // Determine return below or
        // above the average for all
        // subsequent periods
Function Fluctuationmagnitude(cumulative)   // Function to calculate local trend and fluctuation magnitude
    Wave cumulative // Read cumulative demeaned returns from previous function
    Make/O/N=960 Number     // Create a new wave to show the period numbers
    Variable i = 0  // Initialise i
    do
    Number[i] = i +1    // Add the number 1 to the level in the preceding period, so that the first
                        // period carries the number 1
    i += 1
    while(i+1<959)
    CurveFit line cumulative[0,959] /x=NUMBER /D // Generate a linear regression function in which
                                                    // the y values (demeaned cumulative
                                                    // returns are regressed against the x values)
                                                    // (the period numbers)
    Wave Fitted = fit_Cumulative    // Read fitted regression line into Wave named 'Fitted'
    Wave Squareddiff    // Create wave squared differences
    Squareddiff = (Cumulative - Fitted)^2   // Calculate squared differences between
                                                        //  cumulative demeaned returns and fitted
                                                        // regression line
    WaveStats Squareddiff   // Dtermine statistics of wave squared differences
    Variable Sumofsquareddiff   // Create parameter sum of squared differences
    Sumofsquareddiff = V_Sum //Determine sum
    Variable Fluctuationmagn    // Create wave Fluctuation magnitude
    Fluctuationmagn = Sqrt(V_Sum/960)   // Calculate fluctuation magnitude
End<pre><code class="language-igor"><code>
You can limit a curve fit to a subset of a wave using square brackets like this:
Make/O testWave = p + gnoise(5)
Display testWave
CurveFit line  testWave[40,80] /D
ModifyGraph rgb(fit_testWave)=(0,0,65535), lsize(testWave)=3
I recommend changing your Fluctuationmagnitude to take startPoint, endPoint parameters passed in from a new, higher-level function. The new function would create the wave now created in Fluctuationmagnitude. It would then go into a loop calling Fluctuationmagnitude 30 times, once for each segment, passing startPoint and endPoint as parameters.
In the higher level function you can create a 30-point wave to store the outcome from each invocation of Fluctuationmagnitude. Fluctuationmagnitude would return this outcome result.
BTW, this:
    do
    i += 1
    while(i+1<959)
can be written like this:
Make/O/N=960 Number = p+1
For details, execute:
Also, this:
does not read anything. It creates a reference to fit_Cumulative.
Likewise, this does not create any wave. Rather it creates a reference to an existing wave:
A wave reference is a symbol local to a function the references a wave. For details:
I'm not sure where you want the result to go, but here's a skeleton of what you need to do, assuming that what you want is to save the slope and intercept:
Function SegmentedLineFit(Ywave, Xwave, seglength)
    Wave Ywave, Xwave
    Variable seglength
    Variable nsegments = floor(numpnts(Ywave)/seglength)
    Variable i
    Make/O/D/N=(nsegments, 2) fitAandB      // you probably want to make this more general by allowing a customized name
    for (i = 0; i < nsegments; i += 1)
        CurveFit/Q/W=2 line, Ywave[i*seglength, (i+1)*seglength - 1] /X=Xwave
        Wave W_coef
        fitAandB[i][] = W_coef[q]
The advice of both of you has been really helpful. On that basis I created the functions below.
Function HurstCalculation(cumulative, Xwave, length, segmlength,nsegments)  // Create Hurst Calculation function
    Wave cumulative, Xwave      // Create waves
    Variable segmlength, length, nsegments  // Create variables
    Variable FittedLine = SegmentedLineFit(cumulative,Xwave, length, segmlength, nsegments)
Function SegmentedLineFit (cumulative,Xwave, length, segmlength, nsegments)     // Function to calculate segmented Curve Fit
    Wave cumulative, Xwave      // Create parameters cumulative (returns) and Xwave (= time scale)
    Variable segmlength, length, nsegments  // Create paramaters segmlength (= length of segment), length (= length of time
                                            // series for price variable) and nsegments (= number of segments)
    Variable i  // Create local variable i
    Make/O/N=(length-1) LogWave = Ln(XWave) // Transform time scale into natural logarithm
    Variable Summedsquaredresids    // Create local variable sum of squared residuals
    Make/O/N=(length-1) Squaredresids   // Create wave to which residuals for each of the successive curve fits are written down to
    Make/O/N=(1, 1) Fluctuation // Create wave to which square root of average residuals is written down to
        for (i=0; i < nsegments; i += 1)    // Repeat cuve fit calculation for each equal size segment
            CurveFit/W=2/Q line Cumulative[i*segmlength, (i+1)*segmlength-1] /X=LogWave /R  // Carry out curve
                Wave Res_Cumulative // Determine residuals for each curve
                Squaredresids = Res_Cumulative^2    // Determe squared residuals for each curve fit
        WaveStats/Q Squaredresids       // Determine statistics for the entire wave Squaredresids
        Summedsquaredresids = V_avg // Determine average value of wave
        Fluctuation = Sqrt(V_avg)   // Take square root of the average value
Eduard
To play with the function I would like to change the Xwave depending on the length of the segment. In case of a segment length of 16, I would like to
set the first 16 points of the Xwave equal to 1 up to and including 16 and to repeat these values 60 times for an entire series length of 960 in terms of
return values (and 961 in terms of price values). (So far I created the Function SeriesCalc separately in order to test it. Later on, I would like to integrate
it with the other functions and determine the number of segments, depending on the length of a segment.)
The Function SeriesCalc does not behave like expected. If I call it by SeriesCalc(961, 16) for each of the 960 points of Xwave the value of -928 is created.
My question: what I am doing wrong.
Eduard
Function SeriesCalc(serieslength, segmlength)   // Function to create variable lengths of segments
    Variable serieslength, segmlength   // Create parameters
    Make/O/N=(serieslength -1) Xwave    // Create X (time) variable equal to series length (for price series)
                                        // minus 1
    Variable nsegments = floor(serieslength-1)/segmlength   // Parameter nsemgents must be an integer
    Variable i, j   // Create local variables
    i=0
    do
        j=0
        do
            Xwave = j+1 - (i*segmlength)    // Set values of Xwave equal to 1 up to latest segment value
                                            // that is the value of 16 if segment length is equal to 16
            j += 1
        while (j < segmlength)
        i += 1
    while (i < nsegments)   // Repeat Xwave values for each of the n segments
I'm not sure that I follow what you are trying to do but I suspect that this statement is wrong:
This sets every point of Xwave every time through the loop. Perhaps you mean something like:
Xwave[i*segmlength+j] = j+1
This is equivalent to a single statement:
Make /O /N=(960) xWave = mod(p,16) +1
For details on this kind of statement:
You will probably have to read this section multiple times and do some experimentation for it to sink in.
Thank you for your suggestions. This delivers exactly what I wished to do. It is indeed a good idea to reread the text about wave references a variety of times to let it sink in and I have started to do just that.
Eduard
