2D Histogram
I have a problem to create 2D histogram. I have two data sets: ISIs in ms (0-500 ms, 250 bin, 250 ms binsize; Vm -60- -45mV, 250 bin, 0.1mV binsize) I've tried the commands below:
•make/n=(250,250) myHist
•setscale x,0,500,myHist
•setscale y,-60,-45, myHist
JointHistogram(data1,data2,myHist) or Function JointHistogram(data1,data2,myHist)
but I have an error message. Can anyone help?
You need to post the JointHistogram function from http://www.igorexchange.com/node/1373 into your procedure window.
Having done that, I was able to successfully execute these commands:
Make /O /N=1000 xData = 500 * p/1000
Make /O /N=1000 yData = -60 + (15*p/1000)
Make /O /N=(250,250) myHist
SetScale x,0,500,myHist
SetScale y,-60,-45, myHist
JointHistogram(xData,yData,myHist)
NewImage myHist
Yes, thank you very much. Meantime I have found my mistake in the function as well. It works fine in my case too and I got a nice contour plot. I have an other question. How can I normalise the matrix of the results of the 2D Histogram?
Also if I would like to represent the 'density' or the number of dots in each bins and I apply the contour plot how can I set values for the z axe and represent in 3D graph?
Thank you very much for your help,
Marti
You have not defined what you mean by normalization. If you only want the output to sum to 1 then execute:
Variable sss=sum(matrix2d)
Duplicate/O matrix2d,normalized2d // never modify the original
normalized2d/=sss
You are not telling us what kind of a 3D graph you want to plot: do you want to plot a surface, a scatter or maybe some kind of a 3D bar chart?
Hi A.G.,
Thank you very much for your help, the normalization works fine.
I'm sorry if I wasn't enough precise, I meant the surface plot as a 3D graph. But you are right the 3D bar chart can be interesting as well.
Hi A.G.
I managed to create the surface plot as well. Thanks!!!!
Marti
WaveMetrics, Inc.[/quote]
Marti,
Typically histograms are plotted in a bar-chart mode (although that is partly a matter of taste). AG was perhaps too modest to mention his Gizmo3DBarChart.ipf that comes with Igor, in the Wavemetrics Procedures:Gizmo Procedures folder.
If you don't care for the spacing between bars, then a surface plot will do. Be aware however that standard surface plots interpolate over the grid. If you want flat-topped bins of the histogram in a surface mode, AG had sent me the following procedure for converting to a parametric surface wave:
Function makeParametric(inWave)
    Wave inWave
    Variable rows=dimSize(inWave,0)
    Variable cols=dimSize(inWave,1)
    Variable i,j,val
    Make/N=(2*rows,2*cols,3)/O paramWave
    // fill the x-values
    Variable x0=dimOffset(inWave,0)
    Variable dx=dimDelta(inWave,0)
    Variable curx=x0
    for(i=0;i<rows;i+=1)
        paramWave[2*i][][0]=curX
        paramWave[2*i+1][][0]=curX+dx
        curX+=dx
    // fill the y-values
    Variable y0=dimOffset(inWave,1)
    Variable dy=dimDelta(inWave,1)
    Variable cury=y0
    for(i=0;i<cols;i+=1)
        paramWave[][2*i][1]=curY
        paramWave[][2*i+1][1]=curY+dy
        curY+=dy
    // fill the z-values
        for(j=0;j<cols;j+=1)
            val=inWave[i][j]
            paramWave[2*i][2*j][2]=val
            paramWave[2*i+1][2*j][2]=val
            paramWave[2*i][2*j+1][2]=val
            paramWave[2*i+1][2*j+1][2]=val
