Plotting Waterfall graph problem
Hi all
I got a set of ten data files. I'd like to fit them all into one 3D graph so they can be displayed on one slide.
For the 1st file, I have S1_x & S1_y as the normal x & y waves for a 2D graph.
I have ten, so I have ten separate y waves from S1_y to S10_y, and they all have the same x values in their corresponding x waves.
Here is what I used:
Concatenate {'S1_y','S2_y','S3_y','S4_y','S5_y','S6_y','S7_y','S8_y','S9_y','S10_y'}, wave_n
here n stands for the nth data, so n=1 means it's the 1st data, and the tick labels along this 3rd axis are to be replaced later.
Since they all have the same x values in their corresponding x waves, so they can all share the same S1_x wave.
Newwaterfall wave_n vs {S1_x,*}
But it returns an error message 'Expected a real-valued 2D matrix wave'.
I used the same method before but didn't encounter the same problem.
In addition, if they don't have the same x values in their corresponding x waves. What changes I'd need to make to display these 2D curves on one 3D graph?
Best Wishes
Your Sn_y waves should be 1D waves. Therefore your wave_n wave will be 2D which is what NewWaterfall requires.
You can check the dimensionality of your waves using Data->Browse Waves.
I tried these commands and it seems to work fine:
Make/N=5 wave0=p, wave1=1+p, wave2=2+p
Concatenate {wave0,wave1,wave2}, matrix
Edit matrix
NewWaterfall matrix
Make/N=5 xWave = 10*p
NewWaterfall matrix vs {xWave,*}
In your case Igor's built-in waterfall plot will probably work fine. If you had a different X wave for each Y wave, I would recommend a fake waterfall plot.
Edit matrix
NewWaterfall matrix
Thanks hrodstein
But I don't quite understand what the first command line means.
How do you make Igor regconize xWave represents all the waves concatenated into the matrix by this command?
If you don't understand that command then you need to do the Guided Tour of Igor to learn the basics. Choose Help->Getting Started.
Here are similar commands but with comments to explain what each command does. Execute these commands one line at a time. Execute them in a new experiment so you don't get "wave already exists" errors:
// Make 3 1D waves names wave0, wave1, wave2 with 5 points each
// Display the waves in a table
Edit wave0, wave1, wave2
// Create a 2D wave named matrix by concatenating the 3 1D waves
// Display the 2D wave in a table
Edit matrix
// Create a waterfall plot of the 2D wave
NewWaterfall matrix
// Create a 1D X wave to control the X axis of a different waterfall plot
// Create a waterfall plot using a 2D Y wave and a 1D X wave
