Question: mean() function result doesn't make sense
Hi all, how can this make sense??
How could the second one give a mean that is LOWER than the first one? wave1 are all real values.
print mean(wave1,-Inf,Inf)
735.886
print mean(wave1,1,Inf)
735.812
Thanks
Igor
Simple: if, for example, the first element of the wave is larger than the mean. Try this:
Make ddd=x
•print mean(ddd,-inf,inf)
63.5
•print mean(ddd,1,inf)
64
// now change so that the first element is larger than the mean:
•ddd[0]=100
64.2812
64
I hope this helps,
koensayr
I guess I understood the help file wrong. Are the x1 and x2 the index? the way it was described, I thought it means only include elements whose value is between x1 and x2. (especially since -inf doesn't seem to make sense with index)
JimProuty
koensayr wrote: I guess I understood the help file wrong. Are the x1 and x2 the index? the way it was described, I thought it means only include elements whose value is between x1 and x2. (especially since -inf doesn't seem to make sense with index)
Igor Help File wrote: mean(waveName [, x1, x2 ] )
The mean function returns the arithmetic mean of the wave for points from x=x1 to x=x2.
x1 and x2 are the wave scaling indexes over which the mean is computed.
If you have point scaling, they're the indexes of the wave (array), which start at 0 (0 is the index of the first value in the wave, 1 is the second, etc).
See this Igor help topic to explain what wave scaling is and how x isn't usually the point/index number.
