Extract number out of undefined string chain
Hi
I d like to extract a number out of a string looking like
String Name = "Shot_Exp_System_s12345"
I want to get 12345, which will always be a 5 digit number
however the string in front of it may change, though it will most of the time have " _s" just before the number
any idea ?
I tried
Variable var
sscanf Name, "%*s[_s]%5d", var
Print var
it only sees the string and gives 0
This works for integer numbers, assuming that there are no decimal digits in the prefix string:
Function Test()
    String str
    Variable var
    sscanf Name, "%[^0-9]%d", str, var
    Print str
    Print var
