Motofit Error when using Genetic fitting for neutron reflectivity data
elatter
This is the error message:
GENcurvefit/MAT=2/x=w8341_q/D=fit_w8341_R /k={100,10,0.7,0.5}/TOL = 0.001 motofit,w8341_R,coef_Cref,"1111000000",root:packages:motofit:old_genoptimise:GENcurvefitlimits
I've attached an experiment file with 2 runs as an example- w8339 is ok but not the w8441.
Any help is much appreciated.
Ed
I'll look into this and get back to you. In future please email me directly.
cheers,
Andrew.
December 15, 2011 at 10:35 pm - Permalink
it would be good if you could update to the latest cutting edge version. You can obtain this from:
https://motofit.svn.sourceforge.net/svnroot/motofit/branches/dev/instal…
OR
This updated version does not work with older experiment files unless you convert them. Select the menu option "Motofit->Transfer..."
Fitting those two datasets did not give me any NaN problems.
A.
December 15, 2011 at 10:49 pm - Permalink
December 16, 2011 at 03:18 am - Permalink
December 16, 2011 at 03:33 am - Permalink
