close all graphs without saving
I am constantly generating sets of graphs just to look at, and then I spend too long closing each graph individually without saving. Is there an easy way to close all open graphs at once (without saving)?
Use a user-define function.
Function KillAllGraphs()
    string fulllist = WinList("*", ";","WIN:1")
    string name, cmd
    variable i
    for(i=0; i<itemsinlist(fulllist); i +=1)
        name= stringfromlist(i, fulllist)
        sprintf  cmd, "Dowindow/K %s", name
        execute cmd
You can also make a macro so that you can call it from the menu.
macro  killGraphs()
KillAllGraphs()
Note that if you hold down the Alt key when you click the close button on a graph, Igor won't ask you whether or not you want to save the recreation macro--it will just kill the graph. This also works for other window types such as tables, panels, and layouts.
You can write the KillAllGraphs function without using Execute.
Rather than this:
execute cmd
you can do this:
Dowindow/K $name
This illustrates the general principle that $ converts a string expression to an object name.
For details:
DisplayHelpTopic "String Substitution Using $"
