Recreate Graph / Access to History
If I modify for example a graph, Igor writes everything into the history. Is there a way to write these commands to a string instead, such that I can use them later to recreate the graph?
I searched both forums and Igor help files, but I was not able to find any answer.
lin
DisplayHelpTopic "Saving a Window as a Recreation Macro"
If you just want to keep a specific graph- modification command for later use you can copy the command to a notebook. Then you can execute it if needed form the notebook via right click -> execute selection after selecting the command.
September 22, 2011 at 07:47 am - Permalink
WinRecreation
function.September 22, 2011 at 07:47 am - Permalink
