Lion compatibility
mtaylor
If not, is Wavemetrics planning to update for Lion compatibility?
Apple tends to break old software when it releases a new system and I don't expect this release to be any different.
If I am not mistaken, Igor is a carbon app, which is part of the reason there is no 64-bit version for the mac. Support for PPC (rosetta) is entirely dropped in lion, although I'm not sure if this is a problem or not for Igor.
July 5, 2011 at 01:59 am - Permalink
However, some mac applications still rely on ppc code for a portion of their oprations, even if it's not the binary application itself. Hopefully, Igor no longer has such dependancies.
July 5, 2011 at 03:15 am - Permalink
July 5, 2011 at 05:59 am - Permalink
I don't expect major problems.
If problems arise we will address them with an update.
It is not a problem. Igor is "universal" meaning that it includes both PowerPC and Intel code. The Intel code will run on Intel machines.
July 5, 2011 at 10:09 pm - Permalink
July 6, 2011 at 01:57 am - Permalink
July 20, 2011 at 02:20 pm - Permalink
Is there something I have to do? thanks
July 25, 2011 at 01:46 am - Permalink
Three options:
1) upgrade to Igor 6, or a newer version of Igor 6
2) go back to Mac OS 10.6
3) start using the Windows version of Igor in a virtual machine running windows.
July 25, 2011 at 08:48 am - Permalink
Apple dropped support for PowerPC applications in OS X 10.7 (Lion). Igor has shipped as a universal (PowerPC and Intel) application since Igor Pro 6.00 (2007).
I recommend that you download the 30-dayfully-functional Igor demo and then purchase an upgrade to the latest Igor. When you purchase the upgrade you will receive an activation key that will convert the demo into a licensed copy.
July 25, 2011 at 09:08 am - Permalink
1. Sheepshaver (a PPC Emulator that you can load mac OS 9 on) (assuming your version of igor will run in os 9)
http://sheepshaver.cebix.net/
2. WINE: Try using "wine bottler", or "wineskin winery" to make an intel application out of the windows x86 installer. This avoids the virtual machine, but while I haven't tried it, it does show up as working well in WINEHQ's app database (at least the 5.01 version has been tested).
http://appdb.winehq.org/objectManager.php?sClass=application&iId=690
OK, so I'm playing devil's advocate. But I'm running 6.22 and have no issues in Lion.
July 26, 2011 at 01:23 pm - Permalink
