Finding Peak
Hello everyone,
I am trying to find a peak of an IV-curve. I figured out that I should use "findpeak" command to find the peak of this curve by calling that particular wave.
But I am still having some problems with it on how to use this command and stuff.
Please help me.
I also tried the following code:
assignment="Duplicate /O IG"+iname+" IGTEMP"; execute assignment
Wave/D IGTEMP
findpeak/N IGTEMP
Wavestats IGTMEP
variable VPeakVal=V_PeakVal
variable x=IGTEMP[VPeakVal]
//putting data into the desired wave
wave[wavenumber]=x
//killing sacrifical waves
killwaves IGTEMP
"IG" is wave loaded, and "wave" is the wave data will be stored in.
[quote=alinawaz87]I also tried the following code:
Wave/D IGTEMP
findpeak/N IGTEMP
Wavestats IGTMEP
wave[wavenumber]=x
killwaves IGTEMP
"IG" is wave loaded, and "wave" is the wave data will be stored in.[/quote]
This may not be your only problem, but I don't think the following line is doing what you want it to:
I suspect that you are trying to assign the Y (data) value at the peak location to variable x. However VPeakVal itself is the Y value at the peak. Your wave IG may or may not have a point whose index is VPeakVal. Especially since VPeakVal is likely to not be an integer value, and since wave point indexes are always integer values. So I think that you either want to do:
Variable x = IGTEMP[V_PeakLoc]
wave[wavenumber] = x
or
wave[wavenumber]=V_PeakVal
The two options should produce the same result but the second one is faster and makes the code simpler.
