confidence bands with ODR curve fitting
i can´t perform confidence bands in curvefit when i use ODR=2 (i use this method because i perform fitting with error in both vaiables). on the other hand, igor generates a convariance matrix, which could help me to calculate confidence bands after fitting.
(why igor doesn´t perform confidence bands with ORD???)
in case of perform confidence bands after fitting, i use the "variance of predicted model value" as the manual says, but i found in some books that the "variance of predicted model value" is multiplied by chisquare value in order to obatain the confidence bands... how i should perform the confidence bands with ODR???
i really appreciate you help
reggards
March 10, 2011 at 09:42 am - Permalink
Are you interested in confidence bands, or confidence intervals for the fit coefficients? A confidence band is a contour about the model curve; the confidence interval for the coefficients is a +- error bar about the fit coefficient value.
If you want confidence intervals, this is possible with ODR fitting. Add this to the end of your FuncFit or CurveFit command:
This produces the 95 percent confidence interval; change 0.95 to something else to get other intervals. The 4 selects confidence intervals. Other values of the second parameter will give errors- they select confidence bands and prediction bands for the model curve.
If you really want confidence bands, it is possible to compute after a fit, but not completely straightforword, as it requires partial derivatives of the fit function with respect to the fit coefficients. Are you using a built-in fit function?
Because the code I use to perform the ODR fitting is not my own code, and I don't have ready access to the derivatives required. It would require significant further effort, and at the moment I simply don't have the time to devote to it.
March 10, 2011 at 04:23 pm - Permalink
i'm interested in confidence bands.
i usually use some not built-in fit functions, but this functions have a analytical partial derivate respect to fitting coefficents (for example: Y=a + b/x or something like that)...
thanks
March 10, 2011 at 06:22 pm - Permalink
March 11, 2011 at 11:56 am - Permalink
I just sent the e-mail.
thanks
March 14, 2011 at 11:49 am - Permalink
March 15, 2011 at 11:36 am - Permalink
