scale bar for electrophysiology
schmaud
I want to plot a wave without the axis being displayed, but with a scale bar indicating a time unit and ordinate unit. Basicall this is the common way to show electrophysiology data.
I am likely just miss the right term to search the help function...
A solution or just the right search term would be very appretiated.
cheers
Ralf
To hide an axis, double click on it. In the modify axis dialog, make the following changes:
Axis tab: set thickness of line (middle of dialog) to 0.
Auto/Man Ticks tab: in the automatic ticks group on the left, set Approximately: to 0
Label options tab: Set labels to off
Or, you can bring the graph forward and execute the following command on Igor's command line:
February 23, 2011 at 02:11 pm - Permalink
that was fast... and a great help!
ralf
February 23, 2011 at 02:31 pm - Permalink
