An issue in Global fit 2.ipf
I have 4 sets of data to fit together. The first three sets are fitted with Func. 1 (N1 parameters) and the fourth set is fitted with Func. 2 (N2 parameters). N1 > N2. I want to call the function Func1 before calling the function Func2. In the "Global fits 2", it creates a wave "ScartchCoefs" to store the fitting parameters for each dataset. This wave has the fixed data points (here, N1) determined during initialization. However the wave "MasterCoef" has only (3*N1 + N2) points. Igor Pro gives the aforementioned warning messages when assigning the fitting parameters for the fourth set of data.
One solution is to make "ScartchCoefs" waves for each functions so that it can has the same number of data points as the number of the fitting parameters of the called fitting function.
January 3, 2011 at 01:04 pm - Permalink
I discovered this bug a couple of months ago. I think John Weeks has changed the Global Fit 2.ipf code for future IGOR releases.
January 3, 2011 at 02:54 pm - Permalink
I discovered this bug a couple of months ago. I think John Weeks has changed the Global Fit 2.ipf code for future IGOR releases.[/quote]
And if you send a request to support@wavemetrics.com, I can send you a copy of the latest bug-fixed version of Global Fit 2.ipf.
January 3, 2011 at 03:49 pm - Permalink
