creating waves without predefined names
More specifically, I wrote a program to analyze a single set of data producing 30waves. I want to duplicate waves, perform CurveFit and other analysis. I want to also run this same code on a large batches of data. I do not know how to use Make or Duplicate statement in a loop such that name is of wave is changing. I tried using
Make "mywavename"+num2str(index)
but I'm realizing that Make needs a wave reference not a string.
Read Igor's help about this by executing these commands:
You still need a wave reference, so you might change the above to this:
or, easier but requires at least Igor 6.1:
In both cases, to refer to the wave in subsequent code, use the name w.
December 9, 2010 at 01:34 pm - Permalink
December 15, 2010 at 11:28 am - Permalink
