"Proportional to" symbol with Igor Tex
lscanlonj
I am trying to generate a "proportional to" symbol with Igor Tex for one of my axes labels. I have tried \propto and \proportional and cannot think of many more things to try. I want to avoid using the "alpha" symbol.
I have attached a bare-bones file with a plot which has the y-axis labeled in case I need a minimal working example.
Thanks all
I'm not sure what your ultimate goal is, but if you just need Greek letters and a "proportional to" character, I would not use Igor TeX. I would use Unicode symbols:
I composed that command in the Axis Label tab of theModify Axis dialog. I found all three characters in the Character menu to the left of text composing area.
March 6, 2025 at 04:38 pm - Permalink
A view of the character picker
March 6, 2025 at 04:41 pm - Permalink
John, I had a similar problem a while ago with insertion of a parallel symbol. There is a perpendicular symbol in the character picker, but no companion parallel symbol. Any chance of adding one?
March 7, 2025 at 02:19 am - Permalink
Thank you, works great
March 7, 2025 at 06:13 am - Permalink
@lscanlonj Great! Glad I could help.
@s.r.chinn In Igor 9, I see that character in the picker. See the attached screen shot.
March 7, 2025 at 09:42 am - Permalink
Hi John, I should have clarified that I was after a vertical parallel-bar symbol, not slanted or italic. The unicode character exists, but I do not have it in my available fonts. It is meant to illustrate the parallel counter-part to the vertical-upright perpendicular symbol.
March 7, 2025 at 12:27 pm - Permalink
If you can find the appropriate Unicode character, you can add it to the character picker. See the button at the bottom of the picker.
March 7, 2025 at 05:12 pm - Permalink
