live plot view of multipeak fit with integrated background
Dear All,
After very long time, I am trying with most recent version of the Igor for peak fitting, I see there are lot of packages available, but for multiple reasons I like to have a code for my purpose.
It is a typical spectroscopy data, where more gaussian type peaks are present on top of integrated background.
I got first hand success with below code (which is very simple I suppose):
Function fittryOriginal(w,x) : FitFunc Wave w Variable x return w[0]*exp(-((x-w[1])/w[2])^2) + w[3]*exp(-((x-w[4])/w[5])^2)+ w[6]*exp(-((x-w[7])/w[8])^2)+ w[9]*exp(-((x-w[10])/w[11])^2)+ w[12]+x*w[13]+x*x*w[14] End
Here, are there any way to get each gauss as independent wave that can be plotted and observed on the fly, like g1, g2 etc ?
If I want to use integrated background, instead of poly, I need to import the original raw data and do the calculation over interval, but should I do it inside loop? background code is like below
// Backward loop for background calculation for (m = ndata - 2; m >= 0; m -= 1) // Start from second last point and go to the first bg[m] = bg[m + 1] + w[3] * srcData[m + 1] * dx endfor
Due to very long gap, I nearly got lost coding. Any help can help a lot.
I am not sure I understand you fully, but I assume you want to fit multiple Gaussian functions and a polynomial background, while observing the individual components on the fly. This is exactly what the Multipeak Fit package is for (hence the name). Go to Analysis => Packages => Multipeak Fitting to start the package. There is also a demo where you can learn the basics of this tool: Go to File => Example Experiments => Curve Fitting => Multipeak Fit Demo to load the demo experiment.
October 2, 2024 at 01:34 am - Permalink
