How to assign slices of one wave to another?
I'm trying to make a slider that creates a new wave dynamically from two others by combining them at the index selected by the slider. This would be incredibly easy in Python. If I had two inputs, A and B, and an output C, in Python, using lists, I would write:
C[:sliderValue] = A[:sliderValue]
C[sliderValue:] = B[sliderValue:]
I wouldn't even have to know how big the lists were, as long as they were all the same size.
How would I do this in Igor? Here's my slider proc:
Function SliderProc(sa) : SliderControl
    STRUCT WMSliderAction &sa
    switch( sa.eventCode )
        case -3: // Control received keyboard focus
        case -2: // Control lost keyboard focus
        case -1: // Control being killed
            break
        default:
            if( sa.eventCode & 1 ) // value set
                Variable sliderValue = sa.curval
                wave/z a=root:input_a
                wave/z b=root:input_b
                wave/z c = root:output
                if (waveexists(c))
                    // This is where I need to set the output
            break
    endswitch
Bonus question: what does Igor call a slice? Is it a subwave? Subset? I can't find anything on this topic without weeding through image processing posts.
C[,sliderValue] = A
C[sliderValue,] = B
DisplayHelpTopic "Understanding Wave Assignments"
I'd also recommend getting acquainted with the MatrixOP operation as it might help you write more efficient code.  In particular, checkout MatrixOP functions subRange(), subWaveC() and subWaveR().
Note that Tony's solution specifically uses the lowest dimension of a wave / data (which is also the only dimension of a 1D wave). You need to think a bit more about the assignment in case of multi-dimensional waves such as images. Also, regarding your 'bonus' question, I think you want to look for 'subrange'. While it is not easily possible to pick multiple individual elements of data in a single wave assignment in Igor such as with using 'slice()' in python, you usually can achieve something similar without too much hassle. If you want to look into subranges for wave assignments you can find this in the help chapter mentioned by Tony, specifically here:
DisplayHelpTopic "Indexing and Subranges"
