Stop Button (Again)
I asked this ~10 years ago, but have forgotten what I did back then.
I have a panel interface where the user set some directories and starts the loop with a button. Since the process can be long (1 hour +), there is a request for a stop button. I would like to exit the loop after an image is processed and then continue to write a log file with the status of each image processed. I have the function and loop below.
Question: What do I need to do to read the button push once this function starts?
Function Run_Image_workflow() wave/T Images_to_Process string basepath,QP Pathinfo QuantPath QP = s_path NVAR ImagesLeft Nvar Halt =root:halt variable i,imax imax = dimsize(Images_to_process,0) for(i=0;i<imax;i+=1) //should image be run if (Stringmatch(Images_to_Process[i][%status], "not run")) //done and mask missing are skipped //summary Newpath/C/Q/O Pathsummary, (QP+Images_to_Process[i]+ ":summary") //image NewPath/C/Q/O PathImageOut, (QP+Images_to_Process[i]+ ":OutputImages") //sizes NewPath/C/Q/O Pathsizes, (QP+Images_to_Process[i]+ ":size") //textures NewPath/C/Q/O Pathtexture, (QP+Images_to_Process[i]+ ":texture") process_image(i) ImagesLeft -=1 Images_To_process[i][%Status] ="done" if(halt) break endif endif endfor Save_log_file() end Function StopButton(ba) : ButtonControl STRUCT WMButtonAction &ba switch( ba.eventCode ) case 2: // mouse up // click code here nvar halt =root:halt halt =1 break case -1: // control being killed break endswitch return 0 End
Set up your panel as a "progress window" using DoUpdate/W=<panel>/E=1.
DisplayHelpTopic "Progress Windows"
July 1, 2024 at 01:28 pm - Permalink
Thank you. Also I put the do update in the loop just before I check.
This is what I ended up with
July 1, 2024 at 01:43 pm - Permalink
Looks good!
July 1, 2024 at 04:19 pm - Permalink
