reproduce "Luminescence quenching" at igor Pro 3D Graph samples
keeseong
I am trying to draw the same type of graph as those in "Luminescence quenching" example by using a 2D matrix data. [x, y, intensity].
I could draw the 3D surface plot by using Gizmo.
However, I have difficulty in drawing the 2D contour plot in xy plane.
Could you help me with this figure?
Best regards,
Keeseong
If the Gizmo menu doesn't have an "Append Contours" item in it, first choose "Load Gizmo Procedures".
Then the "Append Contours" menu item will be added to the Gizmo menu, and you can use that to put the contour plot in the xy plane of the gizmo window.
September 12, 2010 at 07:44 am - Permalink
I am using version 6.04.
I tried contour plot by using the "Append Coutour Panel" but I got only contour lines, not contour image.
How can I add an image with a continuously changing color to the conour lines?
That is, How can I use "AppendImage" on the xy contour plot?
Keeseong
September 13, 2010 at 06:50 am - Permalink
See this announcement:
http://www.igorexchange.com/node/1759
September 14, 2010 at 05:20 pm - Permalink
