Floating panel in front of a graph, but more subtle
I would like to have a panel floating in front of a graph, but just a particular graph and not everything. Currently I use an external panel attached to the graph, but would rather like to have things on top of each other. Ideally I would like to have a panel while can be easily moved around and resized. A floating panel is almost what I want, but it is a bit obtrusive because it floats atop all windows. I would be also fine with having a sub-panel pasted into the graph, but I don't see how users could then move and resize things freely without resorting to the tools bar. I was thinking of constantly running DoWindow/B=mainGraph to keep things ordered, but this is maybe a bit fiddly as well. Are there any neat options?
You could make a panel subwindow moveable within the bounds of the graph by reacting to mousedown, mousemoved and mouseup events. Don't forget that subwindow events go to the parent window hook function. It's not obvious to me how to implement resizing. You could have the user adjust expansion (via right click), and resize the subwindow accordingly.
November 24, 2023 at 05:35 am - Permalink
If I understand, you want something akin to this ...
if (front most graph window is my specific graph window)
float my specific panel window on top of my specific graph window
else if (front most window is not my specific panel window)
hide my specific panel window
end if
I believe that WinList returns windows in the order from front (index 0) to back (index infinity), and WinList can search on graph windows versus panel windows. Knowing this, I would wonder whether you could accomplish the above by setting hook functions on your specific graph and specific panel to detect active (versus inactive) status. I think the only thing missing is how to detect the case where both the graph window and the panel window become inactive (i.e. when a different graph window is made active) without adding hook functions to all other windows as well.
November 24, 2023 at 06:53 am - Permalink
Hook code for moving a panel subwindow named P0 within the bounds of its parent:
int inPanel = 0
string strPanel
if (stringmatch(s.winName, "*#P0"))
strPanel = s.winName
inPanel = 1
elseif (!stringmatch(s.winName, "*#*"))
strPanel = s.winName + "#P0"
switch(s.eventcode)
case 3: // mousedown
if (inPanel)
SetWindow $strPanel userdata(drag)="1"
STRUCT DragStructure d
d.startMouse = s.mouseloc
d.StartRect = s.winrect
GetWindow $ParseFilePath(0, strPanel, "#", 0, 0) gsizeDC
d.parentRect.top = V_top
d.parentRect.left = V_left
d.parentRect.bottom = V_bottom
d.parentRect.right = V_right
string str
StructPut/S d, str
SetWindow $strPanel userdata(dragstruct)=str
break
case 4: // mousemoved
if (str2num(GetUserData(strPanel, "", "drag")))
StructGet/S d, GetUserData(strPanel, "", "dragstruct")
variable deltah = s.mouseloc.h - d.startmouse.h
variable deltav = s.mouseloc.v - d.startmouse.v
STRUCT rect newRect
newRect.left = d.StartRect.left+deltah
newRect.top = d.StartRect.top+deltav
newRect.right = d.StartRect.right+deltah
newRect.bottom = d.StartRect.bottom+deltav
if (RectInRect(newRect, d.ParentRect))
// *** on Windows you will have to worry about units here ***
MoveSubwindow/W=$strPanel fnum=(newRect.left, newRect.top, newRect.right, newRect.bottom)
d.startrect = newRect
d.startmouse = s.mouseloc
StructPut/S d, str
break
case 5: // mouseup
SetWindow $strPanel userdata(drag)="0"
break
endswitch
structure DragStructure
STRUCT point StartMouse
STRUCT Rect StartRect
STRUCT Rect ParentRect
endstructure
// point and rect structures must have same units
function pointInRect(STRUCT point &pnt, STRUCT rect &r)
return ( pnt.h>r.left && pnt.h<r.right && pnt.v>r.top && pnt.v<r.bottom )
function RectInRect(STRUCT rect &r1, STRUCT rect &r2)
return ( r1.left>r2.left && r1.top>r2.top && r1.right<r2.right && r1.bottom<r2.bottom )
This works on a mac where we don't have to worry about unit conversion for window coordinates.
November 24, 2023 at 07:34 am - Permalink
Thanks for your replies.
@JJ: Hmm... interesting idea. So if I hide the floating panel as long as the graph is not on top I may be able to manage. Lately, one can autohide them as well when Igor is not the active application. I think I only need to check for the deactivate event on the relevant windows and don't need to involve all other graphs in this (that would be quite overkill). I will try to play around with this idea and see how well this works. The only problem I see is when somehow the deactivate event is unreliable.
November 24, 2023 at 07:39 am - Permalink
A deactivate event on the graph window would happen by activating the panel window or any other window. A deactivate event on the panel window would happen by activating the graph window or any other window. Perhaps Tony's approach using a semaphore userData(...) parameter on the graph and/or panel is needed as well???
November 24, 2023 at 09:21 am - Permalink
After trying the floating-panel approach for a few hours I gave up: It is too messy to detect whether the relevant windows are in the front or not to hide/show the floating panel. Also, floating panels interfere too much with the operation of Igor (copy-pasting is disabled etc.). I now try Tony's approach (thanks a lot for that). Since I had already split-axis dragging implemented for the graph in question, this was straight-forward to implement and works reasonably good. I try to implement resizing as well by detecting whether the mouse is close to the corners. Let's see how well this turns out to work. An external panel involves definitely much less head scratching, but why not try new things once in a while ...
November 25, 2023 at 05:07 am - Permalink
OK, I got it to work nicely. Please find a MWE in the attachment based on Tony's snippet. I just fixed a few things and added edge detection for resizing to the code. Note that this is only useful for small additional panels and graphs, since the sub-window is of course obstructing the view for the plots below.
Try out with:
buildMainGraph(test1)
buildSubGraph("Graph0",test2)
Let me know if you have any suggestions for changes.
November 25, 2023 at 07:14 am - Permalink
Looks great.
I think you need to avoid reacting to resize event for host window. Something like this:
if (cmpstr(sName, s.winName))
break
Otherwise weird stuff happens when you resize a host containing a minimum size subwindow.
November 29, 2023 at 03:35 am - Permalink
Tony, thanks for having a look at the code! I am not sure I understand your comment. What weird things happen? If I would add your snippet, then the whole resize section would become useless and could be cut. The hook function never reacts to the subwindow, since it has no hook. But the resize section is specifically there to shift the sub-window around in case it is in danger of leaving the host window area. This works nicely on windows as far as I can tell. Maybe there is a unit conversion problem on Mac?
November 29, 2023 at 04:14 am - Permalink
OK, then I misunderstood the purpose of the code.
For me on the mac, subwindows get resized sensibly when you resize the host. Without the resizing code everything works quite intuitively. But now I see what you're trying to do.
Perhaps you need
rather than gsizeDC? The subwindow after creation has gsize 2 pixels smaller than the minimum size, so any resize of the host moves the subwindow up and to the left. This may be mac-specific.
note also that a subwindow can be 'squashed' by resizing the host (even with your code active), after which your code prevents the subwindow from expanding back to its unsquashed size. Once the subwindow has been squeezed below the minimum size, CheckRectPosAndSize() is always false and prevents resizing by dragging. In addition, your code fires when Igor tries to expand the subwindow (after it has been 'squashed' by the host) and keeps resizing the subwindow back to its reduced size.
I think this means you need to check that the host is larger than minimum subwindow size before the MoveSubwindow.
November 29, 2023 at 05:34 am - Permalink
OK, I see. Yes, this part might be a bit fiddly. I haven't tested it too much. I basically don't want the subwindow to completely disappear when you resize the host window to a size small enough. The reason is that I save the window position for recreating the subwindow, but if the user somehow managed to resize the host window, then there is no way to get the subwindow back in view other than increasing the host-window size again. Maybe that is not really the right way to do it. I would love to have something like anchor points analogous to annotations here where the subwindow moves with a corner other than top left, but there seem to be nothing like this for subpanels.
Regarding the locked resize, I guess I need to make sure that the subwindow expands back to the minimal size upon active or something to prevent that. I will have a look tomorrow and play around with this a bit more.
November 29, 2023 at 09:12 am - Permalink
Tony, here is a version which addresses all these issue, i.e., the 'squishiness' is preserved and you cannot compress the subwindow beyond its minimal size. Let me know if you find other (e.g., mac related issues).
November 29, 2023 at 07:30 pm - Permalink
in your demo the subwindow is created with one dimension equal to the minimum size, which makes it unmoveable (because CheckRectPosAndSize() is always false).
November 30, 2023 at 03:05 am - Permalink
You are right. I think I had this worked out before. Anyway, setting the check to >= should fix that. See the attached version.
November 30, 2023 at 03:22 am - Permalink
Here now the snippet:
https://www.wavemetrics.com/code-snippet/insert-dragable-and-resizeable…
I have also extended the code to work with multiple subwindows on the same graph, i.e., each subwindow can be dragged and resized individually. Here I noticed a quirk (or even bug?) with window hook functions: If two subwindows are overlapping then s.winName reports the name of the subwindow with lower hierarchy and not the topmost one. This leads to problems with drawing the correct mouse cursor and one is likely to grab a lower subwindow behind other subwindows, but is otherwise unproblematic. I haven't found a workaround yet.
December 4, 2023 at 12:17 am - Permalink
are you sure you have the units right for all Windows screen resolutions?
GetWindow gsizeDC gives you pixels.
MoveSubwindow takes control panel units.
The conversion is
(ScreenResolution > 96 ? pixel * 72 / ScreenResolution : pixel) / expansion
In Igor 8, MoveSubwindow has a bug: if screenresolution is > 96, you need pixel/expansion rather than control panel units.
December 4, 2023 at 01:43 am - Permalink
Tony, thanks for your critical look. As far as I can tell, the posted code works fine for any combination of ScreenResolution > 96 and active graph expansion here on Windows 10 both with Igor 8.05 and Igor 9.05. So I guess I got it right, maybe by accident. How does it look on Mac?
Now I remember that I had this more complicated conversion you mentioned and I was not right. Maybe I have both builds where this was fixed?
December 4, 2023 at 02:05 am - Permalink
Ah, maybe because the host is a graph you can use points rather than control panel units, even though the subwindow is a panel? It works, so no worries.
One more question:
Why do you embed a graph subwindow in a panel subwindow, rather than just using a graph subwindow? I thought at first that you were going to add more controls.
December 4, 2023 at 05:10 am - Permalink
Thanks for checking. Great that it works on your side, too.
Yes, at first I wanted to have a multipurpose panel, where you can add multiple graphs and controls. But even if it is a simple graph, the panel makes sure that the graph is opaque which helps visibility in this case. I couldn't find another solution other than making the graph background 'almost white', i.e., gbRGB=(65534,65534,65534), but I found that somewhat unsatisfactory. Maybe there is another way, but I didn't bother too much with graphs only. The code works also fine with just graphs of course, i.e., replacing this:
Display/HOST=#/FG=(FL,FT,FR,FB) plotThis
with this:
Display/HOST=$mainGName/W=(wL,wT,wR,wB) plotThis
December 4, 2023 at 05:32 am - Permalink
In reply to Here now the snippet: https… by chozo
Seems like a bug to me. These sorts of bugs have cropped up in other places, too- it's just natural when iterating through a list to do it in the forwards direction. I would hesitate to fix it in Igor 9 because it would change behavior of existing code. But maybe Igor 10...
So I made a test case:
Window Panel0() : Panel
PauseUpdate; Silent 1 // building window...
NewPanel /W=(150,77,450,277)
Display/W=(103,67,253,167)/HOST=# junk
ModifyGraph wbRGB=(65535,60076,49151),gbRGB=(65535,60076,49151)
RenameWindow #,G0
SetActiveSubwindow ##
Display/W=(33,22,183,122)/HOST=# junk
ModifyGraph wbRGB=(49151,65535,65535),gbRGB=(49151,65535,65535)
RenameWindow #,G1
EndMacro
And guess what: clicking in the overlap area selects the window that's underneath. So this is more than just a window hook problem.
December 4, 2023 at 01:09 pm - Permalink
John, I see. On the one hand, I am happy to hear that I didn't screw up the code. On the other hand, I guess this means you have gotten yourself another task on your desk then? I hope this is not to difficult to fix.
December 5, 2023 at 05:58 am - Permalink
The fix for the hit testing on subwindows was easy- in a loop, I changed iterators to reverse_iterator. The other problems I found with subwindow activation while working the hit testing were harder!
December 5, 2023 at 04:19 pm - Permalink
