Transparency rgba in Gizmo
Matthew M.
I am trying to create a 3D plot in which the function values f(x,y,z) correspond to the transparentness of each point. I made a rgba wave corresponding to each plotted point with the respective color and transparency values, but I have not been able to implement this in a 2D plot or gizmo. I am using Igor Pro version 9, on windows 10. Any help would be greatly appreciated.
So, you have a list of red, green, blue and alpha values, and you want to, what, plot red vs green vs blue with the point there displaying that color with the associated alpha (transparency) value?
September 5, 2023 at 04:12 pm - Permalink
In reply to So, you have a list of red,… by JimProuty
Sorry for the confusion. I have a list of rgba values, the RGB portion is set to magenta (or any other color), I would like to plot location (x,y,z input) vs output as a single color, but with a variable transparency. To do this I ran the following code and obtained the attached gizmo, following your example. Even though the alpha value for the color wave is specified, no transparency is included in the gizmo.
September 5, 2023 at 04:59 pm - Permalink
You mention xyz input vs output, but I don't see your x,y,z values (if they're not red,green,blue).
September 5, 2023 at 06:01 pm - Permalink
Hello Matthew,
I recommend sending your experiment to support@wavemetrics.com for a quicker response. Looking at the information in your posts I am guessing that you have not created the right Gizmo environment for viewing transparency effects. To learn more about it you can execute:
DisplayHelpTopic "Transparency and Translucency"
In particular, after you display your scatter object, make sure to select Gizmo Menu->Enable Transparency Blend. This will add a few items to your display list that are required for transparency effects. Also, it helps if you have a non-white background to discern the effect that you are looking for.
A shortcut to all of this is to display the scatter object as before and then simply execute:
ModifyGizmo Enhance
I hope this helps,
September 6, 2023 at 08:58 am - Permalink
In reply to Hello Matthew, I recommend… by Igor
Hello A.G.,
Enabling the transparency in the gizmo menu solved my issue. Thank you.
Matthew
September 6, 2023 at 09:23 am - Permalink
