Using ButtonControl function inside another function
Hello all,
Is it possible to use a ButtonControl function, in a standalone way, inside another function. For example, below is a function linked to a button in a panel.
Function SimpleButtonFunc (s): ButtonControl
    String s
    SVAR pa = root:parameter_a
    SVAR pb = root:parameter_b
    print pa + pb
We wonder if it can be used inside another function as,
Function AnotherFunction ()
    // some calculations here
    SimpleButtonFunc()              // does not work
    // or
    string tmp
    SimpleButtonFunc( tmp )    // does not work !
Above example does not work. Is there another way to have such functionality.
Thanks.
First, I cannot at all recommend that you call such a control function somewhere else in your code. This is not the way to do it. Instead, you would want to write a dedicated function which does what you want and then call this function from both your button control and somewhere else in your code, e.g.:
Function SimpleButtonFunc (ctrlName): ButtonControl
    String ctrlName
    doTask()
Function doTask()
    print pa + pb
I also recommend to use the newer structure-based control functions:
Function MyButton(s) : ButtonControl
    STRUCT WMButtonAction &s
    if (s.eventCode == 2)   // button clicked
        doTask()
But if you absolutely have to, you can call a simple (not structure-based) control function just fine by passing nothing for the string input (this obviously does not work if the control name is used in you button function):
SimpleButtonFunc("")
Your above example does not work simply because your input string 'tmp' is not properly initialized:
Function AnotherFunction()
    string tmp = ""
    SimpleButtonFunc(tmp)
