Inserting a standing alone fully made graph in a panel
I have a question.
Suppose I have made and furnished (i.e. labeled, texted, ticked, ..etc) a graph according to my need which is displayed as a stand alone graph (i.e. not embedded in any panel). Now I want to insert that fully furnished and polished graph in a panel which I made earlier. Is there a way to do that? I might be missing something. I went through the manual but it says you make an empty display window in the panel and then add traces to make the graph there. In that case, I need to build the graph again from the scratch which I don't want.
Thanks.
Save the graph as recreation macro, create a panel with a dummy graph and save as well. Then copy & paste the code of the graph to the appropriate position in the panel macro.
May 4, 2023 at 11:20 pm - Permalink
This may give you an idea of how to do this programatically. It relies on the fact that Execute can execute a window recreation macro:
May 5, 2023 at 03:50 am - Permalink
In reply to This may give you an idea of… by hrodstein
Thanks a lot for clarification!
May 6, 2023 at 04:32 pm - Permalink
