Cutting image
alcarar
Dear All,
I'm wondering if any of you could help me. I have a problem with an image attached here
I want to cut/delete from the image the areas where there are no oscillations at the top and bottom.
Thank you very much in advance!
Since you already seem to have my Image Profile tool, you could use this to cut your data. Start the tool and select the regions at the edges you want to remove, then press 'Delete ROI section'. Otherwise you could use Duplicate/RMD. For example, try to execute this in the command line:
Duplicate/O/RMD=[][95,2615] ImagePlot_102, ImagePlot_102_cut
January 31, 2023 at 02:02 am - Permalink
Thank you!
January 31, 2023 at 03:24 am - Permalink
