GetFormula unexpected error
Hi all, I am receiving a weird error that I can't understand:
function printFormula(wave w)
  //a valid wave is passed in at the call
  string s = getFormula(w) // <--Throws execution error 'expected wave or variable'
  print s
I don't understand why getFormula() is throwing an error here. If I enter the same code on the execution line of the debugger (or even on the command line) it works fine.
I can confirm, at least on IP9 and Mac OS. IP7 and 8 seem to work as expected.
It works correctly in a function only if the parameter name exactly matches the wave name.
This is true all the way back to Igor 6!
I'm working on a fix to Igor 9 (Igor 8 is no longer being updated, sorry)
A workaround is to get the wave's full path and use $:
  String path=GetWavesDataFolder(w,2)
  string s = getFormula($path)
  print s
