How to use Killwaves and WaveExists operation for a bunch of waves?
Hello all,
I have two questions.
1) I was wondering if there is a way to use a bunch of indexed, and without indexed waves as the argument of 'killwaves' and 'WaveExists' operation. It seems like 'WaveExists' operation just take only one wave as its argument and in the case of 'killwaves' operation, one needs to manually put all the names of the waves as its arguments which is tedious. Let me explain a little bit more.
I have waves named a_00, a_01,....., a_60, b_00, b_01,....,b_60 (indexed waves), and df, vc, iu, kl, qu,...... (unindexed waves like this). I want to use both the 'killwaves' and 'WaveExists' operation on these waves. I tried to use a loop putting the names of the waves in a string separated by ';', but each time Igor complains about the length of the string (I clearly understand the string is too long to handle by Igor in this case).
2) Is there a way to update a named table without creating any extra indexed table at the same table name? If I run the program, every time it creates a new indexed table at the same name which I don't want.
Thanks a lot to everybody,
Ann
Hi Ann
Where is the error about "string too long" raised? Strings in Igor can be arbitrarily long, though wave names not. There is also no real need to test whether a wave exists or not of you use KillWaves/Z like in the example below:
Or if you have Igor 9 you can be more efficient:
January 26, 2022 at 08:54 am - Permalink
Here is an example of how you can make KillWaves and WavesExists work with a wave reference wave
January 26, 2022 at 02:23 pm - Permalink
You could also use Execute, but I think it's a little old fashioned and there is probably a limit to the length of the string
January 26, 2022 at 02:29 pm - Permalink
If you create a table with Edit that table is updated every time any value in the displayed waves changes. You also cannot Kill a wave displayed in a table. You have to kill the table first, then you can kill the wave. If you want to add waves to an already existing table look at AppendToTable. I don't use tables much.
January 26, 2022 at 03:04 pm - Permalink
Hi all,
Thank you very much for your suggestions. Now it is clear to me, killwaves can be used in a loop to kill all the indexed files easily. Just wondering, can 'WaveExists' be used to take multiple unindexed waves as its arguments?
Ann
January 27, 2022 at 12:34 pm - Permalink
Hi Ann
I'm a bit unclear why there should be a distinction between indexed and unindexed waves. Here is an example snippet that demonstrates that:
If you call MakeWaves() then in the history area the wave name and whether it exists or not will be printed in a list. You can check the new data folder that is created called 'WaveExistsTest' to confirm if it is true or not.
January 27, 2022 at 02:40 pm - Permalink
WaveExists takes a single wave reference as input and returns the truth (0 or 1) as to whether the reference points to an existing wave. It's hard to see what it would do with multiple inputs. Perhaps you want something like what this sequence of commands illustrates:
So one wave of interest was made, and a reference to it was put into the zero row of the wave reference wave. The other elements were never assigned; applying WaveExists to those references will return zero. The final print shows that is exactly the case- row zero of the results wave is 1 indicating that the row 0 wave reference points to a valid wave.
January 27, 2022 at 02:41 pm - Permalink
Thanks a lot everybody for your suggestions and tips. Now I got it.
Ann
January 28, 2022 at 05:40 pm - Permalink
