I would like to a open a file and append some strings to it. What is the command to open a file and write a String to it? Is it possible to keep the file open and write several string sequentially? Or is it possible to just open a file for appending a string?
Use Open/A to open a file to append to it.
Use fprintf with the file reference number from the Open operation to write to the file.
Use Close to close the file when you're done.
Function/S CreateAFile()
Variable refnum
Open refnum
if (refnum)
fprintf refnum, "pi = %g\r", pi
FStatus refnum
String filepath = S_path+S_fileName
Close refnum
return filepath
Function AddToFile(String filepath)
Variable refnum
Open/A refnum as filepath
if (refnum)
fprintf refnum, "e = %g\r", e
Close refnum
Function Test()
String fpath = CreateAFile()
AddToFile(fpath)
The first function creates a new file, writes one line into it, and returns the full path to that file. The second function takes in a string containing a full path to a file, and adds a line to that file. The function test() calls both of those functions in sequence to create a file with two lines.
Clearly an inefficient way to make a two-line file! But it does illustrate the technique. When you invoke test(), a dialog is put up asking you to give a name to the file and choose a location for it. The function should complete without asking you for more information, since the full path to the file is returned from CreateAFile().
The background is that an open file has a read/write position associated with it in Igor Pro. You can query the file position via FStatus. And also set it via FSetPos. And by using Open/A that file position is set to the end internally, whereas Open just leaves it at the start.
Thank you John. This example is helpful. Probably the "fprintf" is not what I need in my code, as I am looking to 'dump' an entire string into a text file.
I would say that if you want to write a string to a text file, fprintf is your best option. Just do 'fprintf refnum, mystring' and you should be good to go. I don't know if there is an intrinsic character limit, but I see no problem to 'dump' an entire string. And even if there was a character limit, its just a matter of splitting up the string into parts.
April 28, 2017 at 08:59 am - Permalink
April 28, 2017 at 10:35 am - Permalink
In reply to by johnweeks
Could you provide an example?
January 10, 2022 at 03:11 pm - Permalink
January 10, 2022 at 03:36 pm - Permalink
January 11, 2022 at 05:16 am - Permalink
In reply to Function/S CreateAFile() … by johnweeks
January 11, 2022 at 06:13 am - Permalink
January 11, 2022 at 06:24 am - Permalink
In reply to I would say that if you want… by chozo
There seems to be a limit of 2400 bytes. The string I am trying to save is 100x larger. :(
January 11, 2022 at 06:28 am - Permalink
then probably you will want to use fbinwrite
January 11, 2022 at 06:41 am - Permalink
In reply to then probably you will want… by tony
Thank you Tony. That solved my issue.
January 11, 2022 at 06:44 am - Permalink
