Returning the name of a caller function?
Hi all,
I'm sure there is a way to do this (perhaps with FunctionInfo), but I cannot figure it out yet. I would like to determine the name of a function that calls another function.
Example code below: if call "foo()" I should see "foo" printed to the history window, and if I call "bar()" I should see "bar" on the history window.
function foo()
  ///do stuff
  subfunction()
function bar()
  ///do other stuff
  subfunction()
function subfunction()
   print whocalledme() ////<---what should this code be?
You can start from
GetRTStackInfo(0) and peel the last name in the list.
