Scroll graph using commands in a function?
I would like to have a graph scroll horizontally from right to left, analogously to a scrolling ticker tape at the bottom of a TV news program, and similarly to what a chart recorder control does. Questions:
1) I can achieve this by pressing the Option key, click on a graph, drag to the left, and let go of the mouse while it's still moving. Can I replicate this behavior through commands in a function?
2) I have approximated this behavior through the function below: increment xAxisMin and xAxisMax by the same amount, and doUpdate. This works ok but the updates seem to occur at not-quite-regular intervals. Any alternative ways to code this capability so that the scrolling is less choppy?
Basically I am looking for a chart recorder control, but one that scrolls through an existing wave rather than plotting live data as it's being acquired.
Function ScrollGraph()
    variable leftEdge = 0
    variable rightEdge = 10
    variable seconds = 0
    wave moveRestState
    Display /w=(50, 50, 750, 150) moveRestState
    ImproveInitGraph(1)
    ModifyGraph mode=6
    SetAxis bottom *,10
    ModifyGraph grid(bottom)=1,manTick(bottom)={0,5,0,0},manMinor(bottom)={0,0}
    ModifyGraph manTick(bottom)={0,5,0,0},manMinor(bottom)={4,0}
    doUpdate
    do
        waitPM(100)
        seconds += .1
        leftEdge += .1
        rightEdge += .1
        SetAxis bottom leftEdge, rightEdge
        //doUpdate
    while (seconds < 40)
End //ScrollGraph
In reply to by jjweimer
[quote=jjweimer]
I have posted code in a recent snippet.
https://www.wavemetrics.com/code-snippet/scroll-through-trace
Hope this gives you a useful starting point.
[/quote]
This works beautifully. Thanks! I have not yet figured out what makes your code scroll so smoothly, as your basic technique (change the horizontal axes' min and max) is similar to mine. But your method for pausing (the sleep command, as opposed to the explicit loop I use in my waitPM function) may execute more uniformly.
The sleep command and DoUpdate will guarantee that the graph re-draws. Your loop doesn't have a chance for the graph to redraw reliably.
Here's just a note in case the goal is to keep this running for a longer time (e.g., to simulate a long acquisition): Running this in a function with a for- or do-while loop keeps the function working hard and may stall other things within Igor (and may actually eat quite a lot of cpu time in some cases). An alternative could be to implement a periodic scrolling (or extension of the data in the background) via a background task. You can read more here:
DisplayHelpTopic "Background Tasks"
