Disable mouse click and drag to offset
This feature (still) drives me crazy. When I switch back and forth between Igor I often accidentally activate the "click and drag wave" feature (normally takes 1 second but when switching programs it doesn't).
This is extremely dangerous when I accidentally change the appearance of my results.
OK, this feature can be useful, but does it need to be in such a common shortcut without a disable option?
OK, you've been a good sport about it, and clearly gave it a try retraining. I have just added a Misc setting to Igor 9 allowing you to disable trace drag.
I also think it should be relabeled as the marketing function.  I had the nickname at a former employ of "Dr Data" and it was asked once is "Doctor" a noun or a verb.  Showed them the trace drag and they replied definitely a verb.
