Disable mouse click and drag to offset
jcor
This feature (still) drives me crazy. When I switch back and forth between Igor I often accidentally activate the "click and drag wave" feature (normally takes 1 second but when switching programs it doesn't).
This is extremely dangerous when I accidentally change the appearance of my results.
OK, this feature can be useful, but does it need to be in such a common shortcut without a disable option?
OK, you've been a good sport about it, and clearly gave it a try retraining. I have just added a Misc setting to Igor 9 allowing you to disable trace drag.
April 30, 2021 at 04:40 pm - Permalink
I also think it should be relabeled as the marketing function. I had the nickname at a former employ of "Dr Data" and it was asked once is "Doctor" a noun or a verb. Showed them the trace drag and they replied definitely a verb.
April 30, 2021 at 04:58 pm - Permalink
In reply to OK, you've been a good sport… by johnweeks
Ha! Thank you John.
May 1, 2021 at 07:38 am - Permalink
Heh. Doctor Data... Figures never lie, but liars sure can figure!
May 3, 2021 at 03:45 pm - Permalink
