Loading JSON File
IgorRaven
I am trying to use the JSON XOP - my first time trying to use an XOP - but having problems with the instructions. The instructions are clear after loading the JSON file into a string.
Question: How do I load the JSON file to a JSON string to then use JSONXOP_GetValue to pass the data into waves?
Thank you!
Best,
Loading an arbitrary file is not exactly straightforward. Something like the following should do the trick:
Function JsonLoadFromFile(string path)
variable refNum
string contents
Open/R/Z refNum as path
if(V_Flag)
return NaN
FStatus refNum
contents = PadString("", V_LogEOF, 0)
FBinRead refNum, contents
Close refNum
return JSON_Parse(contents, ignoreErr = 1)
This returns NaN on error or a valid jsonID in the sucess case.
December 7, 2020 at 06:40 am - Permalink
In reply to Loading an arbitrary file is… by thomas_braun
You might want to
Close refNum
before return? :)
December 7, 2020 at 09:13 am - Permalink
@tony: Thanks. Done.
December 7, 2020 at 11:50 am - Permalink
Great! Thanks, Thomas and Tony!
Best,
December 8, 2020 at 05:32 am - Permalink
JSON_Parse appears to be available on IGOR 8. I am still on 6. Perhaps is time to upgrade!
December 8, 2020 at 05:37 am - Permalink
Thoughts?
December 8, 2020 at 08:15 am - Permalink
Yes I would definitly upgrade. IP8 is so much nicer to use!
December 8, 2020 at 08:42 am - Permalink
Hi
I have a large json file (see attachment). I want to have the values put in igor waves. How can I use the function above in order to do that? Where do I load the file? How can I get this to run?
Cheers
Silvan
April 15, 2021 at 02:14 am - Permalink
@Silvan:
You need the JSON-XOP from https://docs.byte-physics.de/json-xop/. Install it.
And then you can use the below code as a starting point:
Function/WAVE JsonLinesLoadFromFile(string path)
variable refNum
string contents
if(V_Flag)
return $""
FStatus refNum
Close refNum
WAVE/T wv = ListToTextWave(contents, "\n")
return wv
Function ExtractFromLine(string JSONText)
variable jsonID, temp
// fixup non-conformant JSON with NaNs as numbers to NaNs as strings
JSONText = ReplaceString(": NaN,",JSONText, ": \"NaN\", ")
jsonID = JSON_Parse(JSONText, ignoreErr = 1)
if(numtype(jsonID) != 0)
return NaN
temp = JSON_GetVariable(jsonID, "cpu_temperature")
JSON_Release(jsonID)
return temp
Function Parse()
WAVE/T contents = JsonLinesLoadFromFile("E:\\walk_A2.txt")
Make/N=(DimSize(contents, 0))/O cpuTemp = ExtractFromLine(contents[p])
This is not a pure JSON file, it is in JSONLines format, https://jsonlines.org/, where each line is its own JSON document.
Whoever produced that file did also not create a standards-compliant file, as you can not use NaN when a number is expected. I've added some hacky fix for that.
April 15, 2021 at 04:04 am - Permalink
In reply to @Silvan: You need the JSON… by thomas_braun
@ Thomas_braun Genius!!!, thanks a lot. It works, I'm so happy
April 15, 2021 at 04:31 am - Permalink
Sorry Gents, I couldn't find the delete post...
December 31, 2023 at 09:53 pm - Permalink
