Copy Graph Subwindow
jtigor
Is it possible to copy a graph subwindow embedded in a panel for pasting in another application? My tests so far show the entire panel is copied.
This has been addressed here: https://www.wavemetrics.com/forum/igor-pro-wish-list/request-duplicateg…
Basically, you need to create a self standing copy of the graph and then you can do what you want with it.
Here is my current version which works for my specific case:
// calling: DuplGraphInPanelSubwndw("PanelName#GraphName")
// You should end up with new graph, copy,... , kill at the end
// https://www.wavemetrics.com/forum/igor-pro-wish-list/request-duplicateg…
Function DuplGraphInPanelSubwndw(String gname)
String rec = WinRecreation(gname, 0)
Variable lines=ItemsInList(rec, "\r")
Variable i
String newrec = ReFactorWinRec(rec)
Execute newrec
Function/S ReFactorWinRec(WRstr)
string WRstr
string gstr
string fstr, istr, rstr, estr
// remove the /W component
gstr = "((?s).+)(Display/W=\(\\d+,\\d+,\\d+,\\d+\))((?s).+)"
SplitString/E=gstr WRstr, istr, rstr, estr
fstr = istr + "Display" + estr
// remove the /HOST component
gstr = "((?s).+)(/HOST=#)((?s).+)"
SplitString/E=gstr fstr, istr, rstr, estr
fstr = istr + estr
return (fstr)
October 1, 2020 at 07:42 am - Permalink
Jan,
Thanks. I had found this brief thread from earlier this year https://www.wavemetrics.com/comment/19627#comment-19627, but had dismissed it since the need was to use the graph in Igor. Of course, I missed one use, to permit user to export as TIFF. For now, I will avoid the subpanel issue completely, but may return to it when I have more time.
October 1, 2020 at 08:35 am - Permalink
