how to calculate interquartile range of numeric wave
Hi all,
I am wondering, if there is a function in igor to calculate interquartile range of a numeric waves. The alternative is to calculate the first and third quartile. However, I still need a command to calculate these 2 quartiles.
My code in progress is as the following:
#pragma TextEncoding = "UTF-8" #pragma rtGlobals=3 // Use modern global access method and strict wave access. Function medianGaussian(JVmatrice) wave JVmatrice // 2D wave Variable sum=0 Variable i=0 // We use i as the loop variable. Make/O/N=(dimSize(JVmatrice,1)), JV Make/O/N = (dimSize(JVmatrice,0)), tempwave Make/N=800/O tempHist;DelayUpdate do tempwave = JVmatrice[p][i] JV[i]=median(tempwave) Histogram/C/B={-7,0.1,800} tempwave,tempHist;DelayUpdate CurveFit gauss tempHist /D print(JV[i]) //calculate inter quartile range //print(W_coef[1]) //print(W_coef[2]) //print(W_coef[3]) //print(W_coef[4]) i += 1 while(i < dimSize(JVmatrice,1)) return JV[i-1] End
Use StatsQuantiles. IQR is stored in the variable V_IQR and in the wave W_StatsQuantiles
September 2, 2020 at 04:52 am - Permalink
Thanks for the suggestion sjr51. It works.
September 4, 2020 at 07:33 am - Permalink
