Accessing structure member in Note operation
The compiler doesn't like
Note/NOCR w, sHeader.sHeader
Where sHeader.sHeader references a string structure member.  The compiler reports "expected a keyword or an object name" pointing to the "." in the structure reference.  A very quick look through the manual turned up nothing on this syntax.  I can work around this by first assigning the member to a string and using the string in the operation.  Am I missing something in using a structure reference in the Note operation or is this a limitation of structures?
I feel as though I've encountered this before, but can't recall the details.
Jeff
In order to investigate I had to create a minimal self-contained example:
Structure MyStruct
    String sHeader
EndStructure
Function Test()
    Make/O wave0 = p
    STRUCT MyStruct s
    Note/NOCR wave0, s.sHeader
Having done that, I can verify the compile error that you report.
The solution is to use ""+s.sHeader. The leading empty string helps Igor's compiler understand that the parameter is a string.
The fact that the compiler needs this help seems like a flaw but there is probably a technical reason for it.
