TransformAxis Tick Formating
Jon
Hi -
I created a plot with several waves appended. The y-axis (left) is a rate vs. x-axis which is a temperature. I have done a custom transform of the y-axis. It worked. However, I have tics from both the left and right y-axis on both sides. So I see double tick marks. How do I only have the left axis tick marks on the left and the right axis tick marks on the right. As an aside, how do I remove the the transformed axis?
I have gone through the Modify Axis settings. The "ticks and grids" Location tap only allows you to remove them completely from both sides.
Thank you.
I'm not quite sure I understand the problem you are describing. Perhaps it would help to post a copy of your Igor experiment file that I could fiddle with some.
Do you mean that the left axis has "Crossing" selected as the Location in the Ticks and Grids tab of Modify Axis dialog? But you want a different style for the Transformed axis? I went to a lot of trouble to make Transform Axis use the same axis styles as the main axis... But you can, in fact, select the "MT_Left" axis in the Modify Axis dialog and change the appearance.
To remove a Transform Axis, select Graph->Transform Axis->Untransform Axis.
June 1, 2020 at 11:23 am - Permalink
Here is the figure. As you can see the left and right axis have double ticks. One pair of ticks is from the original y-axis on left. When I did a transform of the axis to the right side, it generated new ticks (as it should), but it still displays the other ticks. I want the left axis ticks to correspond to the left axis and the right axis ticks to correspond to the right axis.
June 1, 2020 at 12:10 pm - Permalink
In reply to I'm not quite sure I… by johnweeks
I have just uploaded a screen shot of the figure.
June 1, 2020 at 12:11 pm - Permalink
This is the code I wrote for the Axis Transform:
June 1, 2020 at 12:13 pm - Permalink
I've never seen a problem like that. Could you upload a copy of the Igor experiment file? I need to actually poke around at the graph myself.
June 1, 2020 at 04:54 pm - Permalink
Here it is.
June 1, 2020 at 09:11 pm - Permalink
Ah, ha! Turn off Mirror Axis. Double-click the left axis to bring up the Modify Axis dialog. On the Axis tab, Axis section, select Off in the Mirror menu.
June 2, 2020 at 09:25 am - Permalink
Ah, that was easy. Thanks!
June 2, 2020 at 12:16 pm - Permalink
No problem. I might have thought of that from your picture, but it was very helpful to have the experiment file.
June 3, 2020 at 11:57 am - Permalink
