TransformAxis Tick Formating
Hi -
I created a plot with several waves appended. The y-axis (left) is a rate vs. x-axis which is a temperature. I have done a custom transform of the y-axis. It worked. However, I have tics from both the left and right y-axis on both sides. So I see double tick marks. How do I only have the left axis tick marks on the left and the right axis tick marks on the right. As an aside, how do I remove the the transformed axis?
I have gone through the Modify Axis settings. The "ticks and grids" Location tap only allows you to remove them completely from both sides.
Thank you.
I'm not quite sure I understand the problem you are describing. Perhaps it would help to post a copy of your Igor experiment file that I could fiddle with some.
Do you mean that the left axis has "Crossing" selected as the Location in the Ticks and Grids tab of Modify Axis dialog? But you want a different style for the Transformed axis? I went to a lot of trouble to make Transform Axis use the same axis styles as the main axis... But you can, in fact, select the "MT_Left" axis in the Modify Axis dialog and change the appearance.
To remove a Transform Axis, select Graph->Transform Axis->Untransform Axis.
Here is the figure. As you can see the left and right axis have double ticks. One pair of ticks is from the original y-axis on left. When I did a transform of the axis to the right side, it generated new ticks (as it should), but it still displays the other ticks. I want the left axis ticks to correspond to the left axis and the right axis ticks to correspond to the right axis.
The figure. (26.83 KB)
In reply to by johnweeks
This is the code I wrote for the Axis Transform:
Function TransAx_GrowthRate(w, x)
    Wave/Z w
    Variable x
    return x*288.8/10^3/11*3600*2
I've never seen a problem like that. Could you upload a copy of the Igor experiment file? I need to actually poke around at the graph myself.
Ah, ha! Turn off Mirror Axis. Double-click the left axis to bring up the Modify Axis dialog. On the Axis tab, Axis section, select Off in the Mirror menu.
No problem. I might have thought of that from your picture, but it was very helpful to have the experiment file.
