Updating the upper limit of a second set variable limits control
Hi all,
I am just wondering is there any way to set the upper limit of a second setvariable control which will be consequently updated after I insert the value of the first setvariable and do some stuff using a button control i.e. I want the upper limit of the second setvariable will be the value of the first setvariable?
I am attacing a portion of the code to make it clear what I want to do.
#pragma TextEncoding = "MacRoman" #pragma rtGlobals=3 // Use modern global access method and strict wave access. Menu "Macros" "My Joint Histo Panel Creation", MyHisData()//MyJointHisData()//MyJoinHistoPanel() End Function MyHisData() Make/O/N=5000000 timeData=30+gnoise(10) Make/O/N=5000000 energyData=1000+gnoise(10) Variable/G gtimeBin = 50 Variable/G genergyBin = 50 JointHistogram/BINS={gtimeBin, genergyBin}/C/DEST=myJointHisData energyData, timeData // Energy projection (ON TIME BIN AXIS) Make/O/N=(gtimeBin) timeBinAxis Variable/G timebin_1 = 0, timebin_2=0, energybin_1=0, energybin_2=0 Variable row, column, sum_Event=0 Make/O/N=(timebin_2-timebin_1) timeBinAxis For (row=timebin_1; row < timebin_2; row++) For(column=energybin_1; column<energybin_2; column++ ) sum_Event +=myJointHisData[row][column] endfor timeBinAxis[row] = sum_Event sum_Event = 0 endfor End Function ButtonProc(ba) : ButtonControl //button for 2d image bin setting STRUCT WMButtonAction &ba switch( ba.eventCode ) case 2: // mouse up // click code here WAVE/Z timeData WAVE/Z energyData NVAR gtimeBin, genergyBin //NVAR genergyBin JointHistogram/BINS={gtimeBin, genergyBin}/C/DEST=myJointHisData timeData, energyData case -1: // control being killed break endswitch return 0 End Window Panel00() : Panel PauseUpdate; Silent 1 // building window... NewPanel /W=(304,279,993,759) ShowTools/A SetVariable setvar0,pos={0.00,1.00},size={99.00,14.00},bodyWidth=60,title="time bin" SetVariable setvar0,limits={0,inf,1},value= gtimeBin SetVariable setvar1,pos={137.00,4.00},size={114.00,14.00},bodyWidth=60, title="energy bin" SetVariable setvar1,limits={0,inf,1},value= genergyBin Button button0,pos={16.00,30.00},size={165.00,16.00},proc=ButtonProc,title="Draw 2dImage" //for energy projection (ON TIME BIN AXIS) SetVariable time1SetVariableSetLimt title="time1SetVariableSet", proc=SetVarProcForbin_1Limit,value=timebin_1 SetVariable setvar2,limits={0,gtimeBin,1},value=_NUM:0 //here I want the upper limit will be the value of setvar0's value i.e. the number of time bin axis Display/W=(172,120,517,360)/HOST=# AppendImage myJointHisData ModifyImage myJointHisData ctab= {0.1,*,Red,1} ModifyGraph margin(left)=43,margin(bottom)=43,margin(top)=43,margin(right)=43 ModifyGraph mirror=0 RenameWindow #,G0 SetActiveSubwindow ## EndMacro //I think this fragment of code will parse the value of setvar0's but not sure how to extract that Function SetVarProcForbin_1Limit(sva) : SetVariableControl STRUCT WMSetVariableAction &sva switch( sva.eventCode ) case 1: // mouse up case 2: // Enter key case 3: // Live update Variable dval = sva.dval String sval = sva.sval break case -1: // control being killed break endswitch return 0 End
The strswitch approach below would get you started:
March 17, 2020 at 10:18 am - Permalink
