Adding zero values to array
Dear All,
I have created an array (and associated image plot) which contains a function with a square root anomaly. I need to convolute either slices at fixed x values or (preferable) the whole array with a Gaussian in y. However, there are no values (or Nan values?) in the array outside the square route anomaly.
Obviously if I add zero values manually to the wave(s) I can make the convolution work. Is there a neat way to add these to the whole array? Also what would be the command for convoluting the whole array with a Gaussian in y?
cheers, (hope that makes sense!)
Jim
if w is your array and if it contains NaN's then you could use
w= SelectNumber(numtype(w[p][q])==2,w[p][q],0)
to fill in zeros.
[quote]
[/quote]
This is equivalent to:
w= SelectNumber(numtype(w)==2,w,0)
Without indexing, 'w' on the righthand side means "the value of the point in the destination wave that is currently-being evaluated".
