How to make a movie constituted of image loops and audio?
I've wrote a procedure according to the Igor example FM Modulation Movie to make a movie constituted of image loops and audio. The experiment, procedure and pictures for the movie are in the attachment.
Macro MakeMovie(nframes,fRate,wAudio) Variable nframes=NumVarOrDefault("gnframes",10) Variable fRate=NumVarOrDefault("gwFPS",30) Variable wAudio=NumVarOrDefault("gwAudio",2) Prompt nframes,"Number of movie frames" Prompt fRate,"Frame rate" Prompt wAudio,"Sound:",popup "Off;On" Variable/G gnframes= nframes Variable/G gwFPS= fRate Variable/G gwAudio= wAudio DoMakeMovie(nframes,gwFPS,wAudio-1) end // returns error flag Function ValidatePath() PathInfo moviesPath if( V_Flag==0 ) NewPath/o/Q moviesPath, SpecialDirPath("Igor Pro User Files", 0, 0, 0 ) if( V_Flag != 0 ) return 1 // abort or failure endif endif return 0 End Function DoMakeMovie(nframes,fRate,wAudio) Variable nframes,fRate,wAudio wave scar Execute/Q "SetIgorOption VerboseMode=2" newpath/o IgorSpace, "F:" ValidatePath() String fName= "sampleMovie" String fExtension= ".mp4" Variable isMac= CmpStr(IgorInfo(2),"Macintosh") == 0 Make/O/W/N=( 963332/fRate,2) yuanAudio SetScale/P x,0,20/ 963332,"s" yuanAudio variable i=0 do int a=mod(i,4) string nextImage = "pict"+num2str(a+1)+".bmp" imageload /O/P=IgorSpace /T=bmp nextimage duplicate/o $nextimage,w redimension/n=(259,183,-1) w newimage /n=season/s=0 w if(i==0) if( wAudio) fName += "Audio" NewMovie/cf=1/O/F=(fRate)/P=moviesPath/S=yuanAudio as fName+fExtension else NewMovie/cf=1/O/F=(fRate)/P=moviesPath as fName+fExtension endif if( V_Flag!=0 ) Print "OpenMovie failed, err= ",V_Flag return 0 // probably canceled endif endif doupdate AddMovieFrame killwindow season killwaves $nextimage if( V_Flag!=0 ) Print "Add movie frame failed, err= ",V_Flag,", frame ",i if( isMac && wAudio ) Print "Specifing sound may not work on Mac" endif break endif i += 1 while(i<nframes) if( wAudio ) yuanAudio= scar[100000+p] AddMovieAudio/Z yuanAudio if( V_Flag!=0 ) Print "Add movie audio failed, err= ",V_Flag endif endif CloseMovie/Z if( V_Flag!=0 ) Print "Close movie failed, err= ",V_Flag endif Sleep/S 1 // without this, Mac sometimes gives a file not a movie error; DoUpdate did not help PlayMovie/P=moviesPath as fName+fExtension end
When I run this procedure it always turns out :
Add movie frame failed, err= 1 , frame 1
I don't know where the error is.
And when I delete these lines in the procedure
if( V_Flag!=0 )
break endif
the procedure can run as I expect but the image quality in the movie becomes worse with the loop number increasing.
Can someone help me? My Igor version is Igor Pro 8. The operating system version is win10 64 bit. I think the best value for nframes and fRate in the procedure are 20 and 1, respectively.
Thanks a lot!
Deleted my comment ...nevermind, I didn't see the attachments... I hope someone else can help.
August 13, 2019 at 04:31 am - Permalink
In reply to You have to provide more… by chozo
Thank you.
August 13, 2019 at 07:01 am - Permalink
I really don't have sufficient information here but if your AppendMovieFrame command includes the /Z flag then you should pay attention to the value of V_Flag and if it is non-zero you need to determine the reason for the error.
If the movie quality deteriorates with increasing frames you should look at the way you are initializing the NewMovie. If your codec allows you to set the key frame, you will have to reduce the number that you are using because apparently the compression is not keeping up with the relative changes between frames. In fact, it might be a good idea to select a codec that is more appropriate for the type of variations that you have between frames.
August 13, 2019 at 12:31 pm - Permalink
In reply to I really don't have… by Igor
Thank you. I've modified my question. Could you help me further? When I run this procedure, I cannot open a new movie if I omit the /z flag in the Newmovie command.
August 13, 2019 at 06:27 pm - Permalink
I add /cf=1 to the Newmovie command so the picture quality problem has been solved. When I add /z flag to Addmovieframe, Newmovie, etc, the procedure can run although it will get slow down as time passes by, but that may be enough for me. Thank you.
August 13, 2019 at 07:19 pm - Permalink
When you add /CF=1 there is no compression and each one of your images could potentially add a lot of memory which will slow your computer down. Try something like a factor of 10 and see if that improves your performance. I'm not going to comment on the rest of the code because I am not a fan of killing the window each time. Why not simply overwrite the image data, call doUpdate to make sure that it is displayed and then AddMovieFrame.
August 13, 2019 at 07:43 pm - Permalink
In reply to When you add /CF=1 there is… by Igor
Thank you! I've accepted your advice to overwrite the image data instead of killing the window each time.
August 13, 2019 at 08:08 pm - Permalink
