Average Two waves with code
Hello everyone,
I very new to coding Igor pro, I am trying to take two waves and get the y average of them.
I've tried:
Averaging 2 waves: wave0, wave1
and I've tried:
fWaveAverage(WaveList("N_*", "", ";", ""), 1, 3, "NAve", "Nsd")
but I'm not sure how to make a WaveList, I have been coding Igor for only three days, so a lot of the functions are very new to me.
Thanks
To get an average of two waves at some point you will need to combine them into a single wave.
One way to do it is in two steps
concatenate the waves of interest and then take the mean.
In this code the function avg2waves takes two waves and concatenates to a temporary wave (using /FREE) and then returns the mean.
If you want both the mean and sd, this will take a bit more work since in general you can return only one value.
A technique to return more than one value is to make the function return a wave, but this is something for a bit more experienced programming.
In the short run if you want the sd also, I would create a second function that returns that.
May 26, 2019 at 04:53 pm - Permalink
Andy's answer is to get the average value of both waves. I wonder if the OP wants a row-by-row average of the points in two waves (their attempt at fWaveAverage suggests so). This works for two waves.
To expand this for any number of waves that are the same length
A wave list can be generated using the wavelist function and fed into avg2waves as an argument e.g. avg2Waves(wavelist("wave*",";",""))
But instead of going down this route, fWaveAverage has a nice GUI which you can get to from Analysis > Packages > Waves Average.
May 26, 2019 at 10:40 pm - Permalink
Hi guys,
I found this spread very useful, and I'd like to have a relating question: how would this code change if there were more than two waves (let's say around 3-10)? Is there a similar function to avg2waves which could be used the same way?
Levente
May 26, 2019 at 11:20 pm - Permalink
@levente check the second part of my answer.
May 27, 2019 at 01:07 am - Permalink
