time based random access into a video file
Suppose I have a video file(s) named "Video_YYYYMMDD_HHmmSS.format" and I've indexed the start time embedded into the file name in my pair of waves; myIgorDatetime, myFullPathtoFile.
When I'm examining a time series of other measurement data, I need to be able to drop the cursor onto that data and invoke a function to pull up the still image associated with that time.
Function GetImageFromVideoFile( adatetime )
String fullpathtoVideoFile = GetTheRightVideoFileFromIndex( adatetime ) // uses the preIndexed my<waves> described above
Variable offset_seconds = adatetime - TheStartTimeOfTheRightVideoFile; // worked out elsewhere
// Need advice here
// Make an Image Wave appropriate to the resolution of fullpathtoVideoFile
// Use some operation or XOP to go into the video file and unroll the compression to get the still image
return err;
I would first look at the documentation of PlayMovieAction and see what of the above can be handled by the operation.
April 18, 2019 at 04:31 pm - Permalink
