Hello All, so I have a data file with 100 columns and 2000 rows. In some rows some of the cells don't have values and are blank. Is there an easy way to delete these rows?
It could be that this task is a bit more complicated though - can't tell from your question. E.g. if it's one 2D wave or if you want to evaluate if the whole row is blank before deleting...
OK so at the end the columns need to be the same length. The way I would approach this is to make a 2D wave with all the columns in. Then do
// matrix is called matAMatrixOp/O NaNLocWave = SumRows(matA)
This will give a 1D wave that has NaNs for every row where there was a NaN in the matrix (because summing with a NaN gives a NaN). You can then use this to set all points each row where there is a NaN to NaN. You can test for NaN with Numtype == 2.
MatA[][] = (NumType(NaNLocWave[p]) == 2) ? NaN : MatA[p][q]
Next you can use SplitWave to break the matrix into columns. Run WaveTransform ZapNans on each 1D wave (do this in a loop) and then concatenate it back together.
I assumed he loaded the file as separate waves (all the same length) using Load Delimited Text into a table.
This code was presented as a solution:
#pragma TextEncoding = "UTF-8"#pragma rtGlobals=3// Use modern global access method and strict wave access.Macro RemoveRowsWithNansInTopTable()String tableName= WinName(0,2)if(strlen(tableName) == 0)DoAlert0, "Expected table"endif
fRemoveRowsInTableWithNans(tableName)EndFunction fRemoveRowsInTableWithNans(tableName)String tableName
// put references to all of the table column waves into one WAVE/WAVEString info= TableInfo(tableName,-2)Variable maxRows = NumberByKey("ROWS", info)Variable columns = NumberByKey("COLUMNS", info)// includes "Points" columnMake/O/N=(columns-1)/WAVE/FREE waveRefs= WaveRefIndexed(tableName, p, 1)// make a "mask wave" as long as the longest wave in the table// rowHasBlank[row] = 0 means no columns are blank (NaN)// rowHasBlank[row] = 1 means one or more columns are blankMake/O/N=(maxRows)/FREE rowHasBlank = AnyColumnIsBlank(waveRefs,p)// p is also table row number// remove rows from all the waves if any row has a NaN
RemoveRowsWithBlanks(waveRefs, rowHasBlank)End// return 1 if one (or more table column) is blankFunction AnyColumnIsBlank(waveRefs,row)WAVE/WAVE waveRefs
Variable row
Variablei, nWaves= numpnts(waveRefs)for(i=0; i< nWaves; i+=1)WAVE w = waveRefs[i]Variable type = numtype(w[row])if( type == 2)// NaNreturn1// at least one "column" is NaNendifendforreturn0// none were blank if we got hereEnd// remove rows from all the waves if any row has a NaNFunction RemoveRowsWithBlanks(waveRefs, rowHasBlank)WAVE/WAVE waveRefs
Wave rowHasBlank
// work from the end to the start, because DeletePoint changes the effective row Number.Variable nRows = numpnts(rowHasBlank)Variable row= nRows-1doVariable hasBlank = rowHasBlank[row]if( hasBlank )Variablei, nWaves= numpnts(waveRefs)for(i=0; i< nWaves; i+=1)WAVE w = waveRefs[i]DeletePoints/M=0 row, 1, w
endforendif
row = row-1while( row >= 0)End
To remove NaNs from 1D numeric waves you can do
WaveTransform zapnans yourWaveIt could be that this task is a bit more complicated though - can't tell from your question. E.g. if it's one 2D wave or if you want to evaluate if the whole row is blank before deleting...
December 27, 2018 at 12:28 pm - Permalink
In reply to To remove NaNs from 1D… by sjr51
So some of the columns have missing values in some cells and I want to remove all such rows with a missing value. See the attached table.
December 27, 2018 at 12:41 pm - Permalink
MatA[][] = (NumType(NaNLocWave[p]) == 2) ? NaN : MatA[p][q]Next you can use SplitWave to break the matrix into columns. Run WaveTransform ZapNans on each 1D wave (do this in a loop) and then concatenate it back together.
December 27, 2018 at 01:30 pm - Permalink
The OP also asked this question of support@wavemetrics.com, sending in an example file.
December 31, 2018 at 09:58 am - Permalink
