Gizmo surface fly-through/walk-through ?
Hello-
I have a topographical surface generated in 3D by Gizmo. I'd like to make a movie in which the camera (or viewer) performs a fly-through over the surface along a defined path. For example, directing the camera to fly through a valley then over a cliff. So two questions:
1. Has anyone written a code snippet for something like this? For example, a procedure where you can define a 3D path wave which the camera will follow.
2. Is there any advice on what Gizmo commands might be useful for controlling the 'camera' with a 3D path wave?
I would recommend using blender for such an animation. If your Image is a plain 2d image where intensity is height, take a look here: https://www.youtube.com/watch?v=UWFJVvlQIKY&t=57s
It is worth the effort to learn how blender operates and you can also output as VR. It is far more easier than using gizmo here.
December 14, 2018 at 10:56 am - Permalink
I figured this would be the way to go. Thanks.
December 15, 2018 at 06:01 pm - Permalink
You can do this in Gizmo using standard operations. Please check the relevant demo in File Menu->Example Experiments->Visualization->Advanced->LookAt Demo.
December 16, 2018 at 04:33 pm - Permalink
