A Function to Compare DFREF Values
The new DFREF functions are useful. Unless I am mistaken, we might also need a cmpDFR function to check them, otherwise we still have to use the non-DFREF functions. For example ...
    DFREF cdf, xdf
    cdf = GetDataFolderDFR()
    xdf = GetWavesDataFolderDFR(xwave)
    if (cmpDFR(cdf,xdf)==0)
         same two data folders
         two different data folders
It would also be useful for cmpDFR to return the level of the first ABOVE the second, for example root: is two levels above root:test:mydata, so ...
    DFREF cdf = root:
    DFREF xdf = root:test:mydata
    print cmpDFR(cdf, xdf)  ==> 2
    print cmpDFR(xdf, cdf) ==> -2
I've added this to my list to investigate.
In the mean time, you can probably make do with something like this:
Function EqualDFR(df1,df2)
    DFREF df1,df2
    if( DataFolderRefStatus(df1) == 0 || (DataFolderRefStatus(df1) != DataFolderRefStatus(df2)) )
    DFREF dfSav= GetDataFolderDFR()
    SetDataFolder df1
    String df1path= GetDataFolder(1)
    SetDataFolder df2
    String df2path= GetDataFolder(1)
    SetDataFolder dfSav
    return CmpStr(df1path,df2path) == 0
[quote=Larry Hutchinson]I've added this to my list to investigate. ...[/quote]
Thanks. I was not aware of DataFolderRefStatus().
As I was investigating this, I added an optional data folder ref parameter to GetDataFolder:
GetDataFolder( mode, [dfr])
If the optional Data Folder dfr is present, it is used in place of the current data folder.
Given that, the EqualDFR user function above is simplified like so:
    DFREF df1,df2
    return CmpStr(GetDataFolder(1,df1),GetDataFolder(1,df2)) == 0
So, I think that rather than cluttering the function list, I'll just leave it as is.
[quote=Larry Hutchinson]....
[/quote]
Sounds good. Thanks for the suggested code and the changes in Igor to support it!
