Expected wave name, variable name, or operation
function overhead(basewave) string basewave wave baswav = $basewave string New, raw5, raw6, raw7, raw variable col, chan, w5, w6, w7 variable colnum = (numpnts(baswav)/8) raw5 = "L_eventCounter_; L_fullInt_; L_fracInt_; L_typ_" raw6 = "Nt_eventCounter_; Nt_fullInt_; Nt_fracInt_; Nt_typ_" raw7 = "Nb_eventCounter_; Nb_fullInt_; Nb_fracInt_; Nb_typ_" w5 = StringMatch(basewave, "b0w5_e*") w6 = StringMatch(basewave, "b0w6_e*") w7 = StringMatch(basewave, "b0w7_e*") if (w5 == 1) raw = raw5 elseif (w6 == 1) raw = raw6 elseif (w7 == 1) raw = raw7 endif for (col = 1; col < 4; col += 1) New = StringFromList(col, raw) Duplicate /R = (0, colnum) (col, col), baswav, $New appendtotable $New endfor end
Hi I'm getting the error of expected wave name, variable name or operation when I try to initiate this particular function. I even give it existing wave names, but I get the same error message.
Thanks in advance.
I believe the problem is with the spaces in your lists. When you do StringFromList, you will get a space in New. So either removing spaces, or putting "; " as your delimiter in the StringFromList should solve it.
ken
July 17, 2018 at 08:47 am - Permalink
Is baswav a text wave? If so, you need this ...
wave/T baswave = $basewaveJuly 17, 2018 at 08:54 am - Permalink
