Fitting multiple peaks procedure
I am attempting to write a procedure to fit multiple gaussians to numerous spectra. I haven't been able to do it so far, the error being "Singular matrix or other numeric error". If I try the same fit to a single spectrum with the fit multiple peaks package it works!!!
I have tried to use the multiple peaks result as the initial guess to a single fit and it still doesn' work. This is the procedure I am attemting to run:
#include  <Multi-peak fitting 1.4>
Function Gauss3(w,x) : FitFunc
    Wave w
    Variable x
    //CurveFitDialog/ Equation:
    //CurveFitDialog/ f(x) = y0+A1*exp(((x-X1)/B1)^2)+A2exp(((x-X2)/B2)^2)+A3*exp(((x-X3)/B3)^2)
    //CurveFitDialog/ x
    //CurveFitDialog/ Coefficients 7
    //CurveFitDialog/ w[0] = y0
    //CurveFitDialog/ w[1] = A1
    //CurveFitDialog/ w[2] = B1
    //CurveFitDialog/ w[3] = X1
    //CurveFitDialog/ w[4] = A2
    //CurveFitDialog/ w[5] = B2
    //CurveFitDialog/ w[6] = X2
    //CurveFitDialog/ w[7] = A3
    //CurveFitDialog/ w[8] = B3
    //CurveFitDialog/ w[9] = X3
    return w[0]+w[1]*exp(((x-w[3])/w[2])^2)+w[4]*exp(((x-w[6])/w[5])^2)+w[7]*exp(((x-w[9])/w[8])^2)
Function Run()
make/O/N = (10) coef
coef={25147,4683.1,144.85,40.332,983.84,261.7,59.678,1258.7,77.517,130.99}
FuncFit Gauss3 coef test /X = Xwave
Thank you for any inputs.
Luiz
I am afraid it has to do with the way I am loading the data. For some reason if I try to do a regular gaussian fit (with the curve fitting tool) my data does not appear. And if I look at a table from the data the columns names appear with a [][0] next to it, even though each wave has only one dimension.
In case it helps, I attached one experiment with examples;
Luiz
Trial_Fit.pxp (240.6 KB)
hi!
There is something missing in the pxp file: FileImport.ipf
In any case:
I think you are using the /M flag of LoadWave, that's why Igor creates 2D waves (matrices) even if your data is 1D. But the FileImport.ipf file would help debugging ...
gregor
You are right. That has helped. Thanks. I am still trying the fit now. But at least I dont get errors
Thanks!!!
Ok. It finally worked. In the end I had two problems, the wrong input form and I was calling a global wave in a function in the wrong way. In the end, using the the parameters from the Multiple peak package worked.
Thanks!!!
